Which of these cams would fit my needs.
9in wit 3:90 ..and car would weigh about 3700 wit me in it..nd the car would see 85% of the track and about 10% street car..mainly for shows... And 5% parked lol
Here are the cams
1st:
Product Information
Intake Duration: 239 Degrees at .050" Tappet Lift.
Intake Lift: .624" with 1.7 rockers.
Exhaust Duration 271 Degrees at .050" Tappet Lift
Exhaust Lift .624" with 1.7 rockers.
108 Degree LSA
Designed Fordum6.2 to 7.4 Liter Engines With Stock Or Stock Type Intake Manifolds and Rectangular Port Heads.
Extensive Computer Tuning Required.
Suited for applications needing concentrated high rpm power.
Dual valvesprings recommended.
3500 to 7000 RPM Operating Range.
And 2nd
Product Information
Intake Duration: 236 Degrees at .050" Tappet Lift.
Intake Lift: .612" with 1.7 rockers.
Exhaust Duration 262 Degrees at .050" Tappet Lift
Exhaust Lift .646" with 1.7 rockers.
114 Degree LSA
Designed Fordum6.0 to 7.4 Liter Engines With Stock Or Stock Type Intake Manifolds and Rectangular Port Heads.
Aggressive High RPM Power Band.
Exclusive lobe design works well with 1.8 rockers.
Works well with nitrous oxide.
Dual valve springs recommended.
LS 230/246
Product Information
Intake Duration: 230 Degrees at .050" Tappet Lift.
Intake Lift: .600" with 1.7 rockers.
Exhaust Duration 246 Degrees at .050" Tappet Lift
Exhaust Lift .607" with 1.7 rockers.
113 Degree LSA
Designed For 6.0 to 7.4 Liter Engines With Stock Or Stock Type Intake Manifolds and Rectangular Port Heads.
Computer Tuning Required. Broad Power Band.
Aggressive idle and strong mid-range power.
1500 to 6800 RPM Operating Range.
To the OP if you have spent this much money so far why not get something ground to suit your needs? Call up Geoff or get in touch with Pat G and get them to grind you something to meet your expectations.
Got those off geoff page or should i say engpwrsys.com
Im runnin a pretty similar one to the 230/246.. Im
Running a 230/244/114 lsa but this is in my silverado..but now this motor going into my 99fbody
Just my $.02
Just because people have a different opinion on what to run does not take anything away from what those two have done.....
But I will tell you this, open your eyes and broaden your horizon because there are thousands of guys running other cams that work and have worked well... There is a whole entire world outside of the box, Now if your allegance is with those two, thats fine....
But don't put words in my mouth that I never said and I did not see WKMCD say either, now your just being messy ......
Think outside the box, don't be a sheep bro.... I see marketing has power.....
Bozz
But I will tell you this, open your eyes and broaden your arisen because there are thousands of guys running other cams that work and have worked well... There is a whole entire world outside of the box, Now if your allegance is with those two, thats fine....
Bozz
So none of us knows if any Geoff's cams will or will not make power so....you need to think "out of the box".
I have a 416 build going on right now that Geoff has spec'd the cam for. I will post up the results when it is done and we can talk about it more in another thread.
By the way I have broadened my "horizon" because I don't know what an "arisen" is.
But what do I know...
Bottomline:
Your trying to create a controversy and there is no need for that, like I said you were being messy.......
I never said I did not like the Geoff lobes or that they were junk, you said that, I said I do not care for the the cam specs, so once again, quit being messy
and trying to create some flaming controversy.......You "azzumed", no need to spell check that...
Bozz
Bottomline:
Bozz
You're just trying to bow out gracefully now. How about you throw up a cam spec since you don't care about the stated grinds? With your grammar I suspect you will spec out 290/211 480/525 118
To the OP good choice in getting something custom spec'd.
Bottomline:
Bozz
but that's just my opinion from the specs posted.as we all know(or should know)there's a lot more to a cam then specs at .050.
i have a pretty high stall 4400.. 3;90 gears, etc
I second that.....
