head bolts or studs
Old Mar 17, 2011 | 02:30 PM
97lt1stangstomper's Avatar
Default head bolts or studs
So I'm going be running a 600 fly wheel HP 416 on a possibly 150 shot every so often are the studs needed for my motor or just arp bolts good enough
Old Mar 17, 2011 | 02:35 PM
IDRIVEAG8GT's Avatar
What compression? On my boosted L76 at 10:5.1 I'm going with head studs just for the heck of it.
Old Mar 17, 2011 | 02:52 PM
Gordon0652's Avatar
Just do studs.
Old Mar 17, 2011 | 02:59 PM
Sales2@Texas-speed's Avatar
LS1Tech Premium Sponsor
The only reason I'd go bolts would be if I was doing a head swap in a 4th Gen F-body with the short-block remaining in the car. It is VERY tight under that cowl and the studs make it worse (not impossible) trying to do that head swap. Otherwise, studs are great!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old Mar 17, 2011 | 03:55 PM
K motors not even in the car so I'm thinking of studs now
Can't go wrong that way with the engine out of the car!
__________________
Old Mar 18, 2011 | 10:01 AM
NHRATA01's Avatar
From a guy who cheaped out and used the bolts, I'd recommend you use the studs. Easier on the block threads, and in the future if you pull the head again you won't have to spend the hours of pain cleaning the coolant out of the bolt holes.
Old Mar 18, 2011 | 10:04 AM
t/a98's Avatar
I went bolts but with studs you still have to take the back few out to get the heads off an f car, right? so you still would have to clean those bolt holes.
Old Mar 18, 2011 | 10:15 AM
bigboykilroy's Avatar
definately agree! +1
Old Mar 18, 2011 | 10:38 AM
Randy WS6's Avatar
No , i have studs and pulled the heads a few times and never had to take any out. The only pain that i had is loosing the washers. They are a close fit on the stud and are hard to remove with out a magnet especially on the back of the engine were you cant see down in the head. But i would go with the studs any way because you wont haft to clean the threads and get all the water out of the threads , If all the water is not removed you will crack the block from hydro lock when torquing it down and the studs has a better and even clamping force.
Old Mar 18, 2011 | 12:43 PM
ya so studs it is going pick those up from tsp next week,never thought about ow much of mess it would be to clean thes holes on a head swap.
Old Mar 18, 2011 | 01:12 PM
9t8z28's Avatar
What needs to be done to remove cylinder heads on an F-body with head studs?
Old Mar 18, 2011 | 08:17 PM
I would jam an allen wrench in the stud allen fittings and remove them prior to removing the heads... It would in my opinion make it much easier.
Old Mar 19, 2011 | 03:44 AM
From the storys I hear it sounds much easier to lower the motor
Old Mar 19, 2011 | 08:16 AM
Randy WS6's Avatar
I never had any problem removing or installing the heads with studs, just the washer on the studs was a pain to keep up with
Old Mar 20, 2011 | 10:19 AM
9t8z28's Avatar
So you were able to lift the heads off without removing the studs? Did you have to remove anything else?
Old Mar 20, 2011 | 01:06 PM
RENE'S RAGE's Avatar
Take this man advice.
