best l76 heads for $2500 or under?
Old Mar 24, 2011 | 09:16 AM
rennocneb's Avatar
Default best l76 heads for $2500 or under?
Just as the title says im getting ready to do a convertor and cam on my g8 gt and well if its apart lets do the heads as well. I really am having trouble finding much more than stock gm heads that are slightly warmed over. Who out there makes the best head for 2500 or under? that works on the 4.00in bore of the l76. i can maybe slightly stretch that budget if there is a REALLY good reason to.
Old Mar 24, 2011 | 09:35 AM
87silverbullet's Avatar
If you have 2500 to spend and you say you are willing to stretch that budget then by all means get a set of Mast ls3 heads. They are best out right now making some good power numbers with a thick deck.
Old Mar 24, 2011 | 09:47 AM
rennocneb's Avatar
they dont fit a 4.00 inch bore though i dont beleive.
Old Mar 24, 2011 | 10:16 AM
WKMCD's Avatar
WCCH Stage 3!
Old Mar 24, 2011 | 11:14 AM
rennocneb's Avatar
Any of the good new ls3 trickflow stuff work on a 4.00" bore?
Old Mar 24, 2011 | 12:07 PM
Yes they do and they also have small bore ls1 heads. Here you go
http://www.mastmotorsports.com/2010/...sembled&id=361
Old Apr 3, 2011 | 09:51 PM
rennocneb's Avatar
the great head hunt continues. called to check on the black labels by the time you get the better springs and lighter valves they are way out of the budget. 3600 bucks. I mean can they really be that good? the procomp factory cnc'd heads are they 15 degree? im still looking. i just have a real tough time giving 2k for factory 700 dollar heads lol.
Old Apr 4, 2011 | 09:05 AM
Jason 98 TA's Avatar
LS1Tech Premium Sponsor
Hang tight a week or two, we're about to have the first run of PRC aftermarket casting LS3 heads. They'll be well under your target price & be a complete aftermarket casting with smaller runners, big head flow & better p/v!!
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Old Apr 4, 2011 | 09:13 AM
rocket5979's Avatar
Aren't the Mast LS3 heads the ones that use the 0821 casting anyways, which is one of the the G8 GT stock head castings too. If that is the case then the deck thickness should be the same, right?
Old Apr 4, 2011 | 09:15 AM
rocket5979's Avatar
Damnit Jason you guys better not make me want to buy more **** from you!
Old Apr 4, 2011 | 10:22 PM
SOMbitch's Avatar
^^^No the Mast head is a proprietary casting.
Old Apr 4, 2011 | 11:17 PM
White Shadow's Avatar
No...
Old Apr 5, 2011 | 10:41 AM
rocket5979's Avatar
Well shoot I just looked at the article I had read about the Mast heads and sure as **** I was wrong. For some reason I had got it in my head that they had CNC ported 0821 castings rather than making their own. Makes me feel better about the price they were asking for them now.
Old Apr 5, 2011 | 11:27 AM
gsxkid's Avatar
here are the heads i got. i think they are the best bang for the buck.
http://sdparts.com/details/scoggin-d...-center/sd8801
here is an article from hot rod testing the heads
http://www.hotrod.com/techarticles/e...4_casting.html
Old Apr 9, 2011 | 04:44 PM
Z500HP's Avatar
Can you give the details of the heads vs the GM castings? Can I get them bare and untouched and if so how much?
