Lq9 build
Old Mar 25, 2011 | 06:07 PM
sshook2000's Avatar
Default Lq9 build
Would just like some input on my first ls build i have a lq4 block and crank stock ls floating pin rods and stock flat top pistons. Have 317 heads that i am porting and going to get milled .015" with comp cams 918 springs. stock intake and a tsp 224r cam. Will have a 4l80e trans with around 3k stall. I am swapping this in my obs ext cad 2wd. How much power do you think this setup will make? i do not have the pistons or the cam yet would you change anything. Plan to n/a.
Old Mar 26, 2011 | 10:35 AM
ChucksZ06's Avatar
If it was a smaller auto and good exhaust you would make 400 easy but with the big trans it is going to hold down the rwhp numbers a little. Should suprise on the street.
Old Mar 26, 2011 | 10:43 AM
3pedals's Avatar
should run good
Old Mar 26, 2011 | 03:48 PM
sshook2000's Avatar
would you change apart of the build i have been looking at some 799 heads i am thinking about getting instead of the 317s
Old Mar 26, 2011 | 04:53 PM
3pedals's Avatar
nothing wrong with 317 heads.
If money was no object, I would leave the engine simple, and turbo it
Old Mar 29, 2011 | 08:39 PM
sshook2000's Avatar
Which cam tsp 224r or the torquer v2? is the torquer pushing the comp springs to close to the max
Old Apr 6, 2011 | 07:31 PM
sshook2000's Avatar
Anyone
Old Apr 6, 2011 | 07:35 PM
rggbly's Avatar
I mean what are your goals with the build man? are you going for a certain hp/tq number? track time? sound? it all depends on what you're looking for.
Old Apr 7, 2011 | 06:56 PM
sshook2000's Avatar
I want to get the most horsepower and torque with out changing much of the build. Track times dont mean anything. Would like a choppy idle.
