Timing chain for LS2?
Old Apr 21, 2011 | 12:31 PM
chrishurley87's Avatar
Default Timing chain for LS2?
Hey all,
In the next couple weeks I'll be doing a H/C swap on my LS2.
As far as I understand, my current (stock) timing chain is a three bolt system, and the cam I'm getting is also 3 bolt. So what do I need? Just a new LS2 chain? An upgraded/stronger one? Also, what's the difference between the double roller/single roller?
Thanks.
Old Apr 21, 2011 | 12:45 PM
litle88's Avatar
Get the C5R timing chain from Katech and not worry about clearance issues using the double rollers ( two rows of timing chain). Just my .02
Old Apr 21, 2011 | 12:55 PM
Is it just the bare chain? They don't show a pic.
Old Apr 21, 2011 | 01:45 PM
litle88's Avatar
Yup just a chain. You can reuse your current sprockets or you can get new ones. You'll need a puller for the lower sprocket though.
Old Apr 21, 2011 | 05:52 PM
ChucksZ06's Avatar
Unless your car has a lot of miles...why change what is not broke?
Old Apr 22, 2011 | 11:33 AM
Chucks,
A ton of things I've read/heard suggest changing it while in there to do the cam. And this car is getting a supercharger in the future so I'd rather be proactive than reactive.
Do you have any other info that might sway my decision? How much HP is the stock LS2 chain rated for?
Thanks,
Chris
Edit to add: car has 40,000 miles on it
Old Apr 22, 2011 | 08:47 PM
litle88's Avatar
Get a melling or a better than stock flowing oil pump and new lifters while your at it. That's just me, if I'm going in, I'm going to upgrade. Do it once do it right.
Old Apr 23, 2011 | 03:19 PM
Already bought...TSP LS6 Ported oil pump, bullet racing lifters, Comp 987 Dual valve springs. Anything else I'm forgetting after I pick up a new chain?
Old Apr 23, 2011 | 04:02 PM
deuce4935's Avatar
Get this from Brphotrods while you're at it, http://www.brphotrods.com/mm5/mercha...gory_Code=CNV5
Old Apr 25, 2011 | 06:14 AM
litle88's Avatar
Ohh almost forgot...ARP head bolts they're only like 130 bux but well worth it!
