L76/ New Callies Compstar crank tolerances.
Just measured these out real quick and they sound ok to me but wanted to check what you guys think for a Supercharged/street driven/and the occassional full speed highway run. 7000 RPM max, 10-14 PSI, and 10-30 full synthetic oil.
My mains measured out:
1. 0.0020"
2. 0.0018"
3. 0.0018"
4. 0.0020"
5. 0.0020"
And rods are:
1. 0.0019"
2. 0.0018"
3. 0.0022"
4. 0.0020"
5. 0.0018"
6. 0.0022"
7. 0.0020"
8. 0.0023"
Lemme know, thanks guys.
1. 0.0020"
2. 0.0018"
3. 0.0018"
4. 0.0020"
5. 0.0020"
And rods are:
1. 0.0019"
2. 0.0018"
3. 0.0022"
4. 0.0020"
5. 0.0018"
6. 0.0022"
7. 0.0020"
8. 0.0023"
Some will tell you that your mains are a little "loose" for an alum block but trying to tighten can be a pain. I had similar clearances and tried +1 bearings and got near zero clearances. If you need tighter bearings let me know...
LS1Tech Premium Sponsor
If those are main and rod bearing clearances, which I assume they are, you might consider re-titling the thread to reflect that
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Closed ex-Sponsor Account
I will re-check tomorrow. It's dimly lit where I was working last night and couldn't see all too well. And this was like 11 at night I was pretty tired. I don't think .0005 difference should hurt anything really?
tired and poor lighting is a very bad combination when working on engines.
1. 0.0020"
2. 0.0018"
3. 0.0018"
4. 0.0020"
5. 0.0020"
And rods are:
1. 0.0019"
2. 0.0018"
3. 0.0022"
4. 0.0020"
5. 0.0018"
6. 0.0022"
7. 0.0020"
8. 0.0023"
1. 0.0020"
2. 0.0018"
3. 0.0018"
4. 0.0020"
5. 0.0020"
And rods are:
1. 0.0019"
2. 0.0018"
3. 0.0022"
4. 0.0020"
5. 0.0018"
6. 0.0022"
7. 0.0020"
8. 0.0023"
Maybe there is a spec of something behind the bearing shells against the rod housing bore or between the rods which is throwing your measurements off a little bit. Make sure everything is clean everywhere and check them again.
Would also like to know what you are using to measure them, as most DIY'ers do not have accuracy to 0.000x"
__________________
Yep we mic cranks all day long and set bearing clearance on every main and rod journal and Callies is very nice and very consistent!
Yup sorry the false alarm guys I was just using some crap plastigauge, so I went and got a JWK indicator. All the rods were .0021 except for number that I swear was .0019 every time I checked it. But the rod bearings I'm using are ACL coated so there may be a slight variance where I measured. I turned the crank a quarter revolution and it measured out .0020 so I'm happy about that.
