166K gto ls2 compression results....
Old May 8, 2011 | 07:10 PM
vetteboyc5's Avatar
Default 166K gto ls2 compression results....
I am no stranger to the boards here.. I lost my 99c5 with a iron 408 to a wall So I was looking for a new project and came across a nice clean 05 Gto M6 with highway miles for cheap The car appears to be taken good care of.
I am looking to do a budget build..I am a mechanic and will be doing all the work, I am looking to do Heads/cam/Exhaust/small spray..
Compression results came in at 175-180 Across the board on a cold ls2. All are very consistant.
1. I have looked for numbers to compare these results to.. Are these good numbers considering 166k is on the motor?
2. If Im willing to refresh everything, Is this a good motor still for a fairly reasonable Budget build?
Old May 9, 2011 | 03:09 AM
Pwebbz28's Avatar
Thats very good. Consistency is what you really want to look for. 180 is as good as brand new IMO. I would however, replace all valvetrain components including lifters.
Old May 9, 2011 | 05:52 PM
briancb1's Avatar
How much power do you plan to make?
Old May 9, 2011 | 07:28 PM
vetteboyc5's Avatar
I plan on atleast 500 with a modest shot of nitrous.. I was planning on doing new rod bolts and bearings but leaving the pistons themselves alone.
I do agree with the mileage on lifters and the timing chain will all be done allong with new heads..
Old May 14, 2011 | 07:08 AM
TurboAv's Avatar
Do an oil pump while you are in there as well.
Old May 14, 2011 | 09:06 PM
MikeOD's Avatar
That looks like excellent compression results to me. Was that test with the injector fuses pulled and the throttle wide open?
Old May 19, 2011 | 07:51 PM
06blackGTO's Avatar
I think that is very good. I did my goat when it had 120,000 on the odo. with inj. fuses pulled and throttle opened up. And I had 170-180 across the boards.
