LQ4+L92 heads cam and intake?
Im getting an LQ4 soon and some l92 heads off of a G8 GT soon. What compression ratio will this give me (what octane fuel) and what cam should i get for it? Also, he might want to sell me his l76 intake. Would that be better than an LS3 intake or something?
It looks like an assembled ls3 intake can be had somewhat cheaply on ebay, minus the throttle body. This looked pretty interesting.
Also, cost is an issue so a cheap solution is preferable.
Thanks for the advice,
Nick
Nick
With this setup, your compression will be around 9.7:1
No octane issues.... 91 will be fine
For cam selection, enjoy reading this thread
https://ls1tech.com/forums/generatio...s-learned.html
For LS3 vs L76 intake, have a look on these threads
https://ls1tech.com/forums/generatio...-manifold.html
https://ls1tech.com/forums/generatio...6-intakes.html
+1 on the above post.
If you are looking to get the most out of that engine, pay the 25.00 and get a custom cam spec'd for your particular application. I'm running pretty much the same setup that you're asking about, and I will be installing my cam, longtubes, trans, etc starting next week some time. I'm looking for 400+rwhp in the end with a relatively mild cam.
