LS3 heads or TFS 235s (416 build)??
I'm shooting for 550 plus with the mods in my sig on straightline's mustang dyno on an SD tune. Only because I wanna be in the 10's w/full weight and drive home w/ AC on.
I hate the damn HEAT!
That cam looks like its for a very lightened f-body or a vette. In a heavier car that cam would need good gearing and a big stall.
Looks kinda like more for something with a rectangular port head but it will still work with catherdral.
dyno numbers if you want. To me sounds more like shooting in the dark
if i where you i would go for tonys afr 230"s head
check this link out bro some great info on a 416 build
https://ls1tech.com/forums/dynamomet...ted-video.html
#32
you could wait on heads that have no data to support them or track times or
I called the beginning of this week and you could be placed to "order." Said 2 weeks.
#33
The engine made by the Ai for the memeber "Tireburnin" is crazy, I think it is 416 ci with Ai CNC LS3 with Ai Selected Camshaft, Vic Jr. intake with Carb with E85, it made on the dyno over 700 hp (714 hp), and if you calculated as rwhp then it will be around 607 rwhp.
see the link for more information: https://ls1tech.com/forums/dynamomet...-714hp-na.html
An engine with 416ci with LS3 heads and 607 rwhp is considered for me extremely strong as it is almost like a big block output
#34
rich made mine for me in 3 days... great guy and i stand behind him all the way
Ryne@Cms made 490RWHP outa a ls1 with those heads and a big cam
#36
FWIW: the TFS heads are much easier to cam than the L92 heads. Smaller cams make smaller numbers..bigger cams make bigger numbers. Pretty simple.
The l92 heads are much trickier to cam correctly and bigger cams often make less power than the correct smaller cam. Do your research.
#37
