ls3 cam selection..
Old Jun 16, 2011 | 07:38 AM
ls-won-84c10's Avatar
Default ls3 cam selection..
i need a cam for my built ls3 engine. who has the best cams for ls3 headed engines? i understand the Geoff at Engine Power Systems is very good with cam design, but id like some other opinons too. thanks, clint.
Old Jun 16, 2011 | 10:39 AM
xdanny510x's Avatar
Thunder racing vengence tsp
Pat g
Old Jun 16, 2011 | 10:45 AM
TransWS6Am's Avatar
I'd contact Pat G, fill out the sheet with your engine specs, and what you want out of the cam, and he will send you the specs, then just order the custom grind from COMP.
That's what i did, had Pat G spec the cam, and then ordered it from COMP, and rather than wait 3-4 weeks for a custom grind cam, i got it in 3-4 days.
Old Jun 16, 2011 | 02:57 PM
Tram's Avatar
How do we contact Pat G? What does he charge to spec a cam?
Old Jun 16, 2011 | 03:05 PM
98RedZone's Avatar
http://guerragroup.com/camshaft_help.htm
$25, but if you get it ground by his vendor you get $25 off the cam price, I believe.
Old Jun 16, 2011 | 10:52 PM
litle88's Avatar
I would just call Vengeance and talk to Ron or Fraser at AES. He can get you spec'd for one and they'll do it for free.
I called Comp and specd me the cam for my build. Make sure that you have all the info on the heads, intake and exhaust setup that you have so they can make a decision. Ask about the LsR lobes.
Old Jun 16, 2011 | 11:03 PM
TransWS6Am's Avatar
Yep lsr lobes. Thats what I went with.
Old Jun 17, 2011 | 12:28 AM
MattSapp95_T/A's Avatar
I went with Geoff at EPS for my build in my signature...Real good guy to talk to and his cams make great power
