427 build Check Fuel Smell
Custm2500's #1 Fan
have you pressure tested the system?? no leaks? if not then its a tuning problem... like has been mentioned, you can be spot on at WOT or idle or cruise/part throttle, but way out of whack somewhere else.
Plus, there's no way I'd have that kind of $$$ in a build and not have a wideband on it every time it was started.
Thanks for the input guys, i think i have found the tuner i will go with . I will post up when all is said and done.
Just for the record tuner in question is not Chuck Cow. And have really decided to endorse whomever gets my tune right when all is done. I will post up soon.
