Changing setup on my LS2 402. Need some input.
FAST 92mm intake manifold and TB.
Trickflow 220 as cast heads
Texas Speed LS7S Cam 242/250 duration .614/.614 Lift on 114 LSA
11.3:1 compression
This setup is in an RX7 with a T56. Basically I'm looking for something that will pull all the way until 6500-7000rpm while not losing too much on the midrange. I mostly use this car on the street with an occasional visit to the strip and road course. I just want to finish the build without having to go back because I didn't get things right the first time. The above cam and head are still on the mild side for me as far as streetability goes. What would you guys recommend?
11.3:1 compression
