How big!!
Old Aug 10, 2011 | 04:31 PM
MY SRM GXP's Avatar
Default How big!!
What is the largest, I can bore a lq4 6.0l iron block?
Old Aug 12, 2011 | 09:13 AM
redtan's Avatar
On the stock sleeves? Something like 4.030.
On new sleeves? The sky's the limit on that one.
Old Aug 12, 2011 | 09:22 AM
FlamingTA's Avatar
Iron block, sleeves?
Most ppl will have 4.065-4.070 bore if sonic checked. Some can't go that big tho.
Old Aug 12, 2011 | 09:32 AM
82cetuner's Avatar
yeah iron blocks dont have sleeves find a good machine shop and have them check the block and see what they recommend.
Old Aug 12, 2011 | 09:35 AM
chasgiv3's Avatar
ROTFLMAO!!!!!!!!!!!!!!!! Now here's a guy you really want to get advice from...LMAO
You can go 4.06 maximum on those blocks. I personally don't recommend it if you're using it for racing. Also for a Turbo or Super charged application I'd stick with 4.02. If something happens to the block to where it's cut internally then you have some room to have the block bored. But at the end of the day the LQ4 blocks are relatively cheap.
Old Aug 12, 2011 | 09:41 AM
chasgiv3's Avatar
I can't see boring it that large unless you're filling a portion of the block. 4.07 bore would really be on the edge I would think. But man that would be a monster motor for sure with a full stroke.
Old Aug 12, 2011 | 09:43 AM
FlamingTA's Avatar
If NA and sonic tested block 4.065 is at the limit. If FI or big N2O shot you should stay at 4.030.
4.03" will be a very very common size and you would be able to find off the shelf parts very easily.
Old Aug 12, 2011 | 09:45 AM
FlamingTA's Avatar
Alot of places go that big all the time, but you have to find a good block. AES has said they have gone 4.08 but that was for a race engine.
Old Aug 12, 2011 | 10:12 AM
chasgiv3's Avatar
Makes sense. The manufacturing process definitely has some variability to it.
Old Aug 12, 2011 | 11:34 AM
redtan's Avatar
Oh yeah nvm I was thinking of the alum block...whoopsie.
Old Aug 12, 2011 | 01:15 PM
AES Racing's Avatar
We've gone to 4.080 on 6.0 iron, if I recall sonic checked .130", anything less would have issues keeping bores round.
We've installed repair sleeves in 6.0 iron block, the OD of repair sleeve is 4.190"
that didn't break through into water jacket (boring cylinder to 4.190"). That would back up the .130" wall thickness at 4.080.
Old Aug 12, 2011 | 01:28 PM
chasgiv3's Avatar
Fraser, what's the max cubic inch motor you've built out of an LQ4? Bore and stroke?
Old Aug 13, 2011 | 05:04 PM
AES Racing's Avatar
4.080" bore, been running in a street driven silverado.
4.125" crankshaft
If I was to use a bore size of 4.080, i'd prefer it to be under 600hp
4.030" I normally see minimum thickness at .155"
