AFR 230v2
Old Aug 15, 2011 | 11:06 PM
FlamingTA's Avatar
Default AFR 230v2
I just bought a new set of AFR 230v2 large bore 62cc heads. I know that the new 230v2's is a new cnc program on the 225's. When I received the new heads they have "LSx 225 62cc V2" engraved on the sides. Just want to make sure they are the new model. Thanks.
Old Aug 15, 2011 | 11:08 PM
DaFireMan's Avatar
I would call an ask them. May be an honest mistake if there is a mistake. Give them a ring.
Old Aug 15, 2011 | 11:14 PM
yelo04goat's Avatar
might of just had some old cores there that they ran the new program on...
make the call find out for sure..
Old Aug 17, 2011 | 04:12 AM
ctd's Avatar
ctd
I just checked mine, they were installed last winter. They are marked the same as yours 225.
Old Aug 17, 2011 | 06:34 AM
FlamingTA's Avatar
And you bought the 230v2's?
If so I guess they need to update their engraving program.
Old Aug 17, 2011 | 12:14 PM
ctd's Avatar
ctd
Yes mine are 230 V2's. Waited a long time for them.
Old Aug 18, 2011 | 01:16 PM
WADDISME's Avatar
I was going to do the 230s but didn't have the time to wait so I went with TFS 225s. Curious to see some numbers.
Old Aug 18, 2011 | 02:13 PM
FMX05's Avatar
Email AFR's sales department and give them the number on the barcode. That's the build number. They can tell you everything about the heads including ordered chamber size and who they were ordered through. I just had them help me out with a set of used 225's I bought.
Old Aug 23, 2011 | 11:40 PM
GMCtrk's Avatar
Sorry to bring this one back, but what is the difference between the big bore and small bore versions of this head besides the obvious. AFRs website doesn't detail which versions are for what bore sizes.
Old Sep 4, 2011 | 03:24 PM
gto_ua's Avatar
Big bore is intended for 4.06+ applications
small bore works ok with 4+ bore
basically - small bore for ls2+
big bore for ls3,ls7+
Old Sep 5, 2011 | 11:23 AM
kkslds's Avatar
Small bore is for 3.900
large bore is for 4.125
Old Sep 5, 2011 | 02:57 PM
gto_ua's Avatar
Oh really?
Your thoughts dont mean the truth...
What I wrote is how those models should be used in practice.
Old Sep 5, 2011 | 05:53 PM
FlamingTA's Avatar
Oh really?
And your thoughts do? I'm just saying, don't dog another persons thoughts when your's haven't been proven.
There is going to be alot of overlap here. I will be running the big bore on my 4.030" bore. 3.9 and 4.125 is a given on which one would work better. the 4.0-4.07 is where I bet they will both work almost the same, slight flow differences but pretty close.
Old Sep 5, 2011 | 09:01 PM
kkslds's Avatar
Oh really?
I posted what is used in the test examples directly from AFR's website. Obviously they are suited well enough to be used in practice with the bores I stated since that is what they advertise with.
I never said that it was "ideal" for any specific setup, but merely wanted readers to know that it was a possibility to use these heads on a LS1/LS6 combination since it was asked what the difference was. You posted YOUR OPINION on what was ideal and I posted what AFR says will work.
http://www.airflowresearch.com/index.php?cPath=76_78
