LS2 with LS3 Top End: Cam Selection
I’m looking for a cam that will produce good power with a sound that won’t be mistaken for a stock engine. I’m not looking for something overly obnoxious or something that will stall constantly. This is a weekend/fair-weather car so I’m not concerned with fuel economy. The car is not a daily driver. I drive it on the weekends and the occasional autocross.
Here's my setup:
Weight: 2500-2600 lbs with driver
Engine: LS2
Heads and Intake: LS3
Exhaust: Shorty headers with 1.5" primaries, 2.5" collectors/catback and X-pipe (I realize the primaries are small and would be the choking point of the engine but it's all that's available for now. Will be upgraded in the future)
Transmission: Stock GTO T56
Rear: 3.23
Tire: 23" tire
Clutch: Lightweight clutch/flywheel (not sure which one yet)
I'd like to increase the compression using thinner head gaskets but I'm not sure how far I can go and still preserve piston clearance. What effect does timing have on cam selection if any?
From what I've read I should expect anywhere from 450-480+ RWHP with the LS3 top end, depending on cam selection.
Thoughts?
Thanks,
Shane
Here's my setup:
Engine: LS2
Rear: 3.23
Tire: 23" tire
Thoughts?
I like the idea of having a cam that favors exhaust flow. I didn't realize they made cams specifically for cars with exhaust restrictions. I'm sure a better header will be available for me in the future but it's highly unlikely that it would be a full 1.875" long tube. The exhaust friendly cam would probably serve me well for a long time.
One other question about running a thinner head gasket. Maybe I misread this from a different thread but from what I understand, running unmilled LS3 heads and the stock .051 head gasket would yield a lower compression than the stock LS2. Any downsides to this? Or is it just a balance of cam lift vs. gasket thickness to preserve piston clearance?
Thanks again!
Thanks again!
