cam question
Old Sep 26, 2011 | 07:07 AM
jlay's Avatar
Default cam question
Found that my knock was caused from a bad lifter, resulting in a bad spot on the cam. My question is what cam can i use (other than a stock ls2) and still keep all of my other stock components. I'm not looking for more power or anything, but better sound would be great. Thanks in advance. It is going in a 67 camaro with a t-56
Old Sep 26, 2011 | 08:56 AM
Jason 98 TA's Avatar
LS1Tech Premium Sponsor
jlay,
Have you considered upgrading to a complete cam package so you can get a good bit of chop & power in that 67? The packages with springs & pushrods are pretty reasonable & you can add a solid 50rwhp no problem.
http://www.texas-speed.com/p-1157-te...ve-spring.aspx
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Old Sep 26, 2011 | 12:35 PM
jlay's Avatar
I already have chrome-moly push rods and replaced the lifters, that is why I was looking for cams that could be used with the stock setup. Great looking package, just not what I was looking for.
Old Sep 26, 2011 | 05:47 PM
jlay's Avatar
Would a ls7 cam work?
