As the title says can you fit all the ls2 gear onto the gen3 iron 6 litre blocks. I believe the cam sensor hole can be plugged but what about the oil gallery hole at the back.
Don't forget the knock sensors. If you use the LS2 cover, you'll have to relocate them.
A simpler choice may be to use the LS6 valley cover.
