LS2 L92 Heads/Cam - Missing Anything?
L92 Ported Heads (SDPC probably)
Offset Rocker Arm (8x)
Rocker Arm Support (2x)
Head Gasket
Timing Cover Gasket
Timing Set (ordered from Yank)
Water Pump Gasket
Cam (222/230 Pat G + EPS otw)
Pushrods (Hardened otw)
Balancer Bolt (ARP)
LS3 Intake Manifold
LS3 Map Sensor (will require an adapter and whatnot)
Have I missed anything? I'm sure this has been done a million times.
I am also selling them for alot less than SD and they have never been installed there pretty much brand new
I'd also recommend a pushrod length checker so you can determine the correct pushrod length.
