LQ402/8 with ls3 heads- Compression Ratios
Old Oct 23, 2011 | 12:04 AM
Blackbird-WS6's Avatar
Default LQ402/8 with ls3 heads- Compression Ratios
people that are running LQ402/8 with ls3 heads...
can you please post your Compression specs
1-heads are milled to?? (if not stock 70cc)
2-thickness of head gasket??
3-type of piston??
4-Compression Ratio??
just want a general idea
Old Oct 23, 2011 | 02:41 PM
oakley6575's Avatar
Stock LS3 68cc chambers
.051 head gasket
Wiseco flat top -3cc pistons
11.4 compression ratio
Old Oct 23, 2011 | 02:43 PM
.051 head gasket
you run on pump gas without problem?? what are your rear wheele hp/tq numbers??
thanks
Old Oct 23, 2011 | 02:58 PM
oakley6575's Avatar
Yes I live in Las Vegas where it's hot as hell and I run 91 octane. 435hp and 400ftlbs through a 4L80e in a truck. The tune was complete **** so I need to head back to the dyno soon. I bought HP tuners cause I thought the tune was way off, and man I was right. Hoping to get at least another 30hp out of it. I used all stock components in my build with a 231/239 cam as a starting point.
Old Oct 23, 2011 | 09:23 PM
87silverbullet's Avatar
I have close to what oakley has.
Stock chambers (70 cc)
Wiseco Ls3 -3cc pistons
0.040 head gasket
11.45:1
There are guys who have been running 12:1 on pump with no issues. Just have to have a good tune.
Old Oct 23, 2011 | 09:24 PM
0.040 head gasket
11.45:1
pump gas friendly?? and whats your RWhp/tq??
Old Oct 23, 2011 | 09:31 PM
I just did the calculations, my motor will be done shortly and put in the car.
I asked Geoff@EPS(used to be part owner of Thunder Racing) to give me a guesstimate since he spec'd the cam and will be doing the tuning and he estimated 520-540 rwhp thru a TH350.
Old Oct 23, 2011 | 09:34 PM
thats right where i want to be power wise, what motor? 408ci
Old Oct 23, 2011 | 09:35 PM
oakley6575's Avatar
What heads, cam, and intake?
Old Oct 23, 2011 | 09:37 PM
im guessing there ls3 heads on a stock 70cc, dont know if there ported or not
Old Oct 23, 2011 | 09:38 PM
oakley6575's Avatar
They are obviously ported to produce that much power through an automatic.
Old Oct 23, 2011 | 09:41 PM
Ported PRC LS3's , Fast 102 intake, 240/251 636/621 on a 114 on LSL lobes spec'd by Geoff. 416 LS3
Old Oct 23, 2011 | 09:42 PM
thanks you for sharing the info
Old Oct 23, 2011 | 09:43 PM
oakley6575's Avatar
Thats going to be a badass setup. Do you have a build thread?
Old Oct 23, 2011 | 10:02 PM
Not a problem
No I don't. Alot of people have stroker builds going so I didn't want to add another one.
Old Oct 24, 2011 | 07:20 PM
Ttt..
Old Oct 25, 2011 | 03:32 PM
rowdykrowd's Avatar
What would be the best compression ratio for a 408 lq4 ls3 heads twin turbo'd ?
Old Apr 30, 2019 | 01:51 AM
Plus_Ultra_Cars's Avatar
HEY! I'm in Vegas too with a similar build. I was wondering who did your tune (who not to go to, and who you would recommend to use). Also, what are your engine specs, I want to estimate where my rwhp may be when I'm done. Thanks in advance.
Old May 1, 2019 | 06:33 PM
KW Baraka's Avatar
Dude.....Oakley hasn't posted on this forum in almost two years!
