my ls3 h/c combo added twin turbo on my ls2 c6 z51 vette build list
Old 07-14-2012, 04:03 PM
  #541
Imstock2's Avatar
Yea lol I was half asleep when I posted that... Cajun called me and woke me up and we talked for a while.. I'm getting the z06 pinon support and hopefully rpm will replace my main shaft with the z06... The main shaft has cracks through out it and I do believe it flexed under hard acceleration and cracked the inner pinon support.... then broke off.. I'm sure glad everything is still under warranty
Old 07-14-2012, 05:29 PM
  #542
MUSTANGBRKR02's Avatar
So did the rear lock up and cause the main shaft to break?
Old 07-14-2012, 10:08 PM
  #543
Imstock2's Avatar
No the diff did not lock up... Rem I rotated the tires and didn't hear any clunking or anything.. The way everything looks.. The main shaft had to go first.. If the diff internals cracked the way it did before the main shaft broke then the main shaft would of shredded the diffs internals.. Look at those pictures I posted up.. That's what I think happened but I could be wrong..
Old 07-16-2012, 07:41 PM
  #544
Copy & Paste Moderator
VIP1's Avatar
This thread has gone a bit off the rails. Lets skip the attacks and callouts. If it gets worse, I'm locking this thread.
Old 07-19-2012, 12:32 PM
  #545
Imstock2's Avatar
Good update! Although I haven't had the chance to ship the diff out.. I been working with rpm.. BER is going to fix my diff and upgrade it as wel as RPM is doing the same with the transmission.. Awesome vendors and I recomend them. As you see.. outstanding customer service and they realize there are bad parts..
Old 07-19-2012, 12:35 PM
  #546
Burrhos's Avatar
Any out of pocket cost for you?
Old 07-19-2012, 01:48 PM
  #547
Imstock2's Avatar
Shipping the Diff to BER.. Rpm is having the trans picked up at my work place
Old 08-05-2012, 09:11 PM
  #548
Turd Gen Guy
1nasty86's Avatar
Update?
Old 08-06-2012, 01:20 PM
  #549
Imstock2's Avatar
RPM is done with the trans.. I had BER ship the diff to rpm so they could machine the pinion support to fit the 30 spline mainshaft. RPM is still waiting on the diff from BER.. I'm hoping I can have the car done 100% before Aug 18th for the local forum track/dyno day... The way it's going I don't see my new mods being done but atleast I'll have the diff and trans back soon
Old 08-28-2012, 07:40 PM
  #550
Imstock2's Avatar
Ok my buddy wanted to to update this.. I had my rpm transmission with the 30 spline shaft for about a week.. I get my 3.90 diff back with new internals machined to 30 spline Sept first.. I'm doing break in miles for the diff and trans and then loading up heading to ohio.. Had a choice... an 08 r1 or this.. Sept 11th I should receive the Upp TT kit and will be selling my intake,Lt headers, and injectors.. My first ever twin turbo install on a vehicle and well this kit looks quite simple. I'm only gonna be pushing maybe 10 psi with meth.. nothing 2 crazy ya know
Old 08-28-2012, 08:41 PM
  #551
AWDTBSS's Avatar
Old 08-29-2012, 09:50 PM
  #552
Imstock2's Avatar
Not a race car yet m8... still has stock bottom end.
Old 08-29-2012, 10:21 PM
  #553
WheelsUp84z's Avatar
so you couldnt afford to put tires on the car a month ago, but now its getting twin turbos? Sure thing boss!
Old 08-29-2012, 10:57 PM
  #554
Imstock2's Avatar
A few months ago I was kinda worried about getting out.. now I have everything falling in line.. I can spend a few $'s on my ride...well I got some tires now... really wish I could stay in nc for another month.. I'll be rolling around for 3 days until I bounce.. sucks those will be break in miles for trans and diff or I would love to get some final runs in with your group
Old 09-22-2012, 06:51 PM
  #555
Imstock2's Avatar
hmmmm mean thought's? Got most my stuff in today... A little late to install.. looking to start the install next month after I get situated in cleveland...
Old 09-22-2012, 09:21 PM
  #556
djfury05's Avatar
I got to hand it to you. When you say your going to do something/get something, you do it. I like that about you. Good luck with it all the parts look good.
Old 09-23-2012, 01:18 AM
  #557
Imstock2's Avatar
Thanks man.... I really don't see the UPP kit that hard to install.. There's a step by step guide about it and a guy on cf already made a build thread for a c6.. So really no need for me to step by step update this but I will post pictures here and there so yal see I do my own work. Only reason I made this build thread was because so many peps was curious about the ls3 heads on ls2.. I'm in a huge debate between e85 or 93/meth.. New fuel pump will be needed for the e85 and I really don't feel like dropping the drivetrain again for a while
Old 10-09-2012, 06:38 AM
  #558
Imstock2's Avatar
ready for install
little brother double checking my turbo fitment.. kit is a little annoying to install so it's wise to have an extra hand after your ready to call it a day.
Old 11-05-2012, 03:45 PM
  #559
Imstock2's Avatar
ok been a while since I updated this... here's some pictures I took today
Interior is done, installed a/f gauge and boost gauge, relocated battery to trunk
rivit aluminum flashing over the fenders area where I had to cut to prevent debri getting in
fenders fit like a glove, painted intercooler black and left the ic vain aluminum
my entire fuel system I got in today and some new plugs,wires 28ft of stainless line, aeromotive fuel rails, aeromotive eliminator pump with drop in bracket and aeromotive fuel pump controller, aeromotive fuel pressure regulator with gauge and about 220$ worth of fittings
Old 11-05-2012, 10:54 PM
  #560
anfittingsdirect dot com Thats where I get all my stuff from, saves quite a bit of money over most other places
Quick Reply: my ls3 h/c combo added twin turbo on my ls2 c6 z51 vette build list
