416CI 600rwhp are they out there?
Happy to stand corrected. I guess that means that UK rwhp isn't quite the same as what they get over in the states...
Actually I do intent to get an idea where mine ends up versus your benchmark, but the car has a stock LS7 now, it should run for the first time some time in the next two weeks.
BTW, my Z06 is a daily driver, full weight full leather full everything, and 6.74 sc. acceleration time was measured side by side against a Porsche Carrera GT.
And sorry for the extra 2Ci difference related to your original question...but you might use it as an archive info.
Christian
Christian
![Name: 202graph.jpg
Size: 140.2 KB](https://ls1tech.com/forums/attachments/generation-iv-internal-engine/675623d1501791986-416ci-600rwhp-they-out-there-202graph.jpg)
Have you thought of going with a solid roller and spinning it a bit more to getting the # you want?
I haven't seen a 416 with true 93 octane compression (below ~11.8:1) make anywhere close to 600rwhp. I'm not saying it can't be done, or that someone hasn't done it, but I haven't seen nor read about it. And the ones I have read about have not been close to 600rwhp..
Your ace in the hole are the ITB's.
If you ever have your car down for a long build, let's talk about you sending me your Kinsler ls7 itbs so I can do an A/B test against my Jenvey Ls7 itb setup. I would split shipping with you, and pay for the dyno time. We can do it through a shop so you felt comfortable you would get your itbs back right after the test.
![Secret2](https://ls1tech.com/forums/images/smilies/LS1Tech/secret.gif)
![The Pimp](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_pimp.gif)
Haven't heard of a 600rwhp 416 yet...but you should have no problem hitting 550+. A local guy hit 550 with WCCH LS3 heads and a Texas Speed cam on his 418 (6 speed C5), so I would think the extra 50hp over that setup is out there somewhere, and ITBs are an excellent start to finding it...but you already knew that.
Yes sir...
Re the shipping i am in the UK!!
Still waiting on the shims to land so i can get the valve springs set up...
I'll post up as soon as she gets on the dyno.
