L76/L98 7000+ rpm on standard bottom end
#41
The scaling at the bottom of the graph looks to be a little bit out!
#42
yeah its got my stock 3.07 diff in and wasn't recalibrated, as 4.11 go back in this week. normally ~170kph.
this is a cross-over of two models, old VZ shape, but had a newer VE engine. so it has a E38 pcm to control the L76 and 4l65E. factory can run E10, but retuned to run E85. the newer VE, is fully fuel flexible with sensor in tank.
if we start making hp up to 7k and running a knife edge tune i may retrofit the sensor in tank. basically the provision is there in the pcm.
