max LS4 bore with stock sleeves
I was under the assumption that it would be the same as any other Lxx 5.3L, but some others in the LS4 section of the forum have their doubts.
thanks in advance!
what's inside, just let them find out the hard way, i bet will cost you less, and be a lot faster, with less down time less work, and the end product will put a smile on your face, trust me.
A RWD LSx would work, because I'm getting the new 6T75 trans which has the "RWD" bolt pattern.
However, I have free machine shop access, as well as engine assembly...but I don't want to take advantage of them and make them resleeve the block if I don't have to I order to get more cubes
However, I have free machine shop access, as well as engine assembly...but I don't want to take advantage of them and make them re sleeve the block if I don't have to I order to get more cubes
Good man, so which block will you be using, the LSX block can net you a 440 Ci with the 4" stroke, and with 11 to 1 comp you could be making 600 whp, but require a lot of drive train beef ups, still think a stock LS3 is a viable solution and will still use your drivetrain.....Remember fwd will have lots "less" power loss thrue the drive train, and minus 120 front end lbs, compare to the LSX block, and you'll be saving a lot of money...just beef up the trannie before it goes in so will live, with the extra power, and use headers, and cam if you desire.
which is plenty for this car. Thanks for the ideas! Don't hesitate to PM me if you have any questions, by the way i have a real nice cam for that combo if you need it, will give you a keeler deal..
Plus, the fwd trans is very fragile; barely able to handle the stock 5.3, much less anything more powerful.
Yep!
