Post details of your L92/LS3 headed combos here...
#61
Stock LS2 bottom end with stock unmilled LS3 heads, intake, injectors
EPS 222/230 .591/.608 114+4
25% underdrive pulley
spec super twin/AL flywheel+PP (36 lbs total)
No a/c, no p/s
GTO t56
3" AL driveshaft
3.23 getrag clutch diff (cts) / 24" tire
1.5" primary, 2.5" collector, Shorty headers -->2 cats, 2 resonators, muffler with 2 in's and 2 out's
I'll probably try to fab some 1.75" or 1.875 long tubes this winter and maybe have the heads milled a little. Should be worth some good HP gains.
No a/c, no p/s
GTO t56
3" AL driveshaft
#62
2000 T/A
LS2 Block .005 overbore
stock crank
Eagle H-Beams
Manley flat tops with 2cc vr
LS6 oil pump w/ shimmed spring
L92 milled .030 other than that they're untouched
stock gaskets ~ 10.8:1 cr
L76 intake untouched with FAST 92mm TB
LG G6x3 cam
LS7 lifters, and stock rockers
ASP underdrive pulley
Kooks 1 7/8
Texas Speed ORY "the new style"
mufflex 4" cat back with single outlet Magnaflow
15.5 lb flywheel
RST street twin clutch
Chromoly D/S
Moser 12 bolt with 3.90 gear
Don't have any track times but it put down
499.2 HP and 454 TQ
I was pretty happy for being untouched heads and intake and virtually stock cubes still.
stock crank
Eagle H-Beams
LG G6x3 cam
Kooks 1 7/8
15.5 lb flywheel
Chromoly D/S
499.2 HP and 454 TQ
#63
Moderator
2000 T/A
stock crank
Eagle H-Beams
LG G6x3 cam
Kooks 1 7/8
15.5 lb flywheel
Chromoly D/S
499.2 HP and 454 TQ
stock crank
Eagle H-Beams
LG G6x3 cam
Kooks 1 7/8
15.5 lb flywheel
Chromoly D/S
499.2 HP and 454 TQ
#66
2009 Potiac G8GT
4115 lbs race weight
221/231 .608/.610 111 LSA+0 w/1.85 rockers, DoD lifters afm still functional
Heads ported milled .035
Modified L76 intake by Rick Crawford
1 7/8 longtubes
3.45 gears
2600 stall
11.65 @119.12 with street tires
1 7/8 longtubes
3.45 gears
2600 stall
#67
Sure thing here it is. We lost tach signal for a second which is what peaked the torque, on the pass jsut before this one it made 454 tq. This pass looked to be even higher on tq, but the tach signal messed it up. but anyway here it is.
By strkt_blwn at 2012-07-13
#68
basic setup:
402 ls2
callies crank/rods
wiseco pistons
11.6-7:1 CR
LS3 intake
PTM 92mm
PRC 2.5 L92's 64cc
Pat G cam 244/256 .625/.630 114 lsa
M6
Rxt twin disk
moser 9" 4.10's
28" DR's
car made 554/510 on a pretty hot NA tune
On the bottle 665/760 with very conservative tune (pulled 12* for 175 shot(
(480/490 on graph is nitrous tune NA..ran like crap)
93 octane, kit pulling fuel off the rail.
ALSO, nevermind the RPM's they were off all day, Made a pull to 6800.
402 ls2
callies crank/rods
wiseco pistons
11.6-7:1 CR
LS3 intake
PTM 92mm
PRC 2.5 L92's 64cc
M6
Rxt twin disk
moser 9" 4.10's
28" DR's
#70
Love this thread...Im in search of a Lq9 or LS2/LS3..I've been searching for complete takeouts and they are somewhat reasonable on prices for the Lq4/LQ9..I can buy a set of L92 or 243 heads. All im wanting to do is put my 1987 caprice LS in the 11s and have it as a pro touring deal. With some of the threads on this forum I think I can get there.
