Removing gto motor from bottom tips?
I've done many Camaros from the top but since I may have a lift available I figured through the bottom seems way easier.
Thanks.
After just working under my GTO this past weekend and having it fresh in my mind, I'm not sure it's even possible to go out through the bottom without removing the steering rack and a bunch of suspension stuff. And the front crossmember is secured to the frame with TTY one-time-use bolts and has to be properly aligned with the frame using a special tool.
My understanding is that the A/C compressor can be unbolted from the block and moved out of the way and secured with a piece of wire.
