HELP, 418 has to much crankcase pressure, blowing out everywher!!!!
#42
I refuse to accept that this is a problem inherent in these engines, esp when I have seen quite a few without this problem.
It should not be accepted nor should it be seen as the norm.
If this instance of spitting the dipstick tube out were on an SBC it would be laughed at and considered a wrong build, but on an LS engine its "nothing to be addressed"? Even with 5 breathers and water hose all over the intake, that should not be seen as acceptable for a street driven car.
On this part we can disagree, that way the argument is ended with both of us being right in our own minds.
#43
#44
^ sorry I will not bow down to you because your post count is higher. Ill stop arguing with you though because it is detracting from the thread now. And because you have no valid argument over what I say.
#45
BTW nice ninja edit. I totally missed that you added the entire part after There is nothing to address. I should have quoted you first.
Tight ring pack.....hmmm....whatever you say. I never said it would not make more pressure, I am saying the pressure that you quantify as normal is not normal.
What is the diff between your LS3 427 and the LS3 427 that I am currently working on? The main diff is, yours has some blowby or "excess pressure" issues that necessitate the need for breathers, and this one works with a standard 3/8 size PCV line. One from the valley to the intake and one from the pass cover to the TB. No catch can.
Please tell me what you mean by "tight ring pack" also. I am interested in this.
#47
Ding Ding.
#49
1 Post
82cetuner,
I would be curious as to what the short-block builder has to say about this. All too often it seems they pass the buck and put the blame somewhere else. IE.: Wrong oil, bad break-in, broken PCV, etc.
#50
A few finishing remarks.
The catch can off the valley cover restricts pcv,
The catch can off the valley cover restricts pcv, did you not see me say that more then once already in this thread? My engine doesnt push any oil without a catch can, it does WITH a catch can. That is why I have to use breathers. Pay attention.
Also, there was no ninja edit, else it would have said post edited. WTG.
#52
holy snap i just relized something the catchcan routing I have is OPPOSITE of yours in that picture the top tube on my catch can runs to the intake and the bottom tube runs to the vally cover, so is mine wrong?.
P.S. my breather sits at a angle, could it be possible its just mist hitting it then collecting and pooling then leaking out?.
on a side note though I think I am losing a descent amount of oil more than i would think normal. i belive quit a bit is comming out of the breather its not forcibly comming out or anything but just leaking down the breather
#53
#54
Why dont you take the catch can off and run it normal instead of running a catch can and 3 breathers? Doesnt make much sense.
And I know what you put at the beginning of that post. It ended after the there is nothing to address. Now you go back and edit the rest of your posts. You only know the argument after the other side has given their rebuttal then you change it just a tad.
#55
86 the breathers. They will cause you nothing but problems in your situation. If you are pushing oil out of them now, I have a feeling it will just get worse.
FYI if you are not careful you can pull unmetered air into your engine through the breathers too. This was brought up in another thread.
#56
well wouldnt the air comming threw the catchcan also be unmetered and it goes directly into the intake, and its like that from factory.
I dont understand your statment how can air from the valve covers ever make it into the combustion chamber even if they are sucking air?? it would have to connect to the intake somehow like the catchcan does
#57
Catch can air is metered in a stock setup because the factory pcv draws air from behind the MAF, so the air has already been read and can be recycled indefinitely.
However due to pressure differentials inside the engine, the amount of air that does get in isn't measurable and does not effect AFR. Breathers (venting in general) are a good thing, gectek is mistaken.
#58
Case in point, put a vacuum gauge on your intake manifold. Now take your oil fill cap off. Notice the vacuum doesn't change. Same concept applies to breathers, the air never makes it to the intake or combustion chamber, they simply allow excess pressure or vacuum in the lower end to bleed off.
#59
im ganna swap the catchcan around and see if it still leakes if it does I will add a breather to the driver side valve tubing. my goal is to stop losing oil I dont really care how I do it as long as the compression test and leakdown test are ok.
Here is to hoping I dont have to do a rebuild!!!!!!!!
#60
The higher flowing air inside your intake system actually creates a low pressure system that the higher pressure inside the engine is drawn to. The air does not push its way into your engine via the PCV system. That is how the PCV system draws excess crank pressure and oil vapors from your crankcase and into the intake stream for it to be reburned and relieved. Any air that is taken in by the PCV system is not accounted for in the standard VE calculations, that is why they have orifices on the valve covers and for the valley cover. So they can slow down the amount of transfer. This is how a downdraft or exhaust tube works also. The higher the pressure is, the faster it works.
You are mistaken on how a pcv system works in the first place. If you are running your engine at idle with the one pcv hose running from your pass valve cover to your TB and you take the cap off, you should notice some odd things. That is unless when the car was tuned you already had breathers on it. Then the airflow readings will be skewed in the wrong direction to try to take into account that unaccounted for air.
Let a newer dodge run then take the oil cap off it and see what happens.
You know how I know that? Because I did it.
Do not worry yourself Diet Coke, I will def test this whole theory out this coming week.
What I dont understand is that if your engine was running so good without a catch can, then why would you spend the extra money and cobble up your engine bay with a catch can then 3 breathers. Maybe there is something else you just arent saying.
