Help compression ratio
Old Apr 7, 2012 | 09:24 PM
Brennen's01SS's Avatar
Default Help compression ratio
Ls2 402
Gm mls gasket
-2cc dish pistons
243 heads with 63cc combustion chamber
I've tried using the calculators but having trouble. Please help
Thanks.
Old Apr 8, 2012 | 06:40 AM
RezinTexas's Avatar
do you know your deck height?
Clearance Volume = Piston Deck Volume at TDC + Piston Dish Volume + Head Gasket Volume + Combustion Chamber Volume
Swept Volume = pi x Bore^2 /4 x Stroke
Compression Ratio = (Swept Volume + Clearance Volume) / Clearance Volume
