Cam swap question L92/Remove VVT
Old May 16, 2012 | 01:27 PM
Sting67ray's Avatar
Default Cam swap question L92/Remove VVT
What do i need to change to put a non-vvt cam in a L92 besides the cover and cam sensor?
Old May 16, 2012 | 01:50 PM
Jimbo1367's Avatar
From TSP (link & bottom) ]
"VVT Delete Kit
item# 25-VVTDelete
-Share on emailShare on printMore Sharing ServicesShare
-VVT Delete Kit
-All the parts you need to remove the Variable Valve Timing System from your VVT vehicle.
-VVT Delete Kit, Includes: LS3 Front Timing Cover with Cam Position Sensor, 3-Bolt Cam Gear (4X), and ARP Camshaft Bolts. "
http://www.texas-speed.com/p-724-vvt-delete-kit.aspx
Old May 16, 2012 | 03:09 PM
litle88's Avatar
You can also buy a lot of those items used except the Ls2 lifters and lifter trays which I would get new any how. Just my .2
Old May 16, 2012 | 03:18 PM
Sting67ray's Avatar
Jimbo,
That was perfect link thanks.
What else should you replace besides the springs,and cam. I am looking for say 450 Rear wheel horsepower.
Thanks,
Tom M
Hy82e's Avatar
Are most guys using the original oil pump? Any pressure problems, or problems when using with a fbody or cts-v pan?
Old May 16, 2012 | 09:12 PM
Jimbo1367's Avatar
Some. Chris @ MAST says the AC Delco PF-48 filter has the pressure relief valve buit in. FWIW
No problems. Pan depends on swap. Camaro4 pan here.
Originally Posted by Sting67ray
Jimbo,
TVMWhat else should you replace besides the springs,and cam. I am looking for say 450 Rear wheel horsepower.
Hardened push rods Highly recommended
Old May 17, 2012 | 08:32 AM
Sting67ray's Avatar
Jimbo,
Thanks again
Old Nov 15, 2014 | 04:45 PM
Gonzalo Bravo's Avatar
"VVT Delete Kit
item# 25-VVTDelete
-VVT Delete Kit
I installed a Comp Cam 3bolts camshaft on a L92. Swap a LS3 cover and 4X cam gear. But do I need to swap the sensor also or can I use the stock L92's cam sensor (3 wires)???
This is the L92 sensor (12591720) that I am using...
Attached Thumbnails Cam swap question L92/Remove VVT-img_0623.jpg
Old Nov 23, 2014 | 11:42 AM
Project GatTagO's Avatar
I believe a new cover comes with a new sensor installed.
Andrew
Old Nov 28, 2016 | 07:01 AM
5'5 Big Bob's Avatar
The lifters will stay in the heads with the dial method correct?
