Busted lifter, trashed cam....Need opinions!
So now I'm face with a dilemma, do I get a new cam (same specs) or go a little bigger?
The car made awesome power for being a bolton,cam car, and with a little custom grind cam. Not that dyno numbers are everything, but its one of the highest bolton/cam ls2's I've seen, and whether it came from the cam or I just have a strong motor I don't know.
Anyway, here's the dyno sheet....450/414, on 91... at Cunningham Motorsports (Murietta, CA)
Also made 458/415 on a mustang at Craven Performance (St Peters, MO)
-Svede
-FAST 102
-Cam
-UDP
-LT's, 3" Catless, Super 40's
Uploaded with ImageShack.us
So here's I've got going....feel free to point out anything I should add or change.
ARP Hex Head Bolt Kit - $109.99
GM LS2/L92/LS3/L99 Cylinder Head Gaskets - $73.98
GM LSX Harmonic Balancer Bolt - $4.99
GM LS7 Lifters - $139.99
Texas Speed Ported LS6 Oil Pump w/ New O-ring - $195.98
New cam (same specs) - $355
Debating on these-
Katech C5-R Timing Chain (LSx) - $149.99
SLP Timing Chain, 2005 LS2 Double-Roller - $139.95
Lunati Street Linkbars - $375.86
-"Designed for engines with a maximum RPM operating range of 6200 - 6500" I run mine to 7000...any input on these being more/less reliable than the LS7's because of the extra RPMs?
Valve Springs....
Currently running Patriot Extreme .660 lift springs.
30k on them. They're off the heads and everything looks perfectly normal. Any reason to be looking at getting new ones?
And as far as the rockers go..stock with 96k on them. Normal wear, but everything checks out. I was going to get the comp trunion upgrade and just change them out. Any reason to order a whole new set of rockers with the upgrade?
Pushrods are hardened 7.400's. I'll be double checking the needed length and ordering new ones if need be.
Blackonblack - that was the first thing I though about, but i checked them with a borescope and they look fine.
Martin-230/232 .613/.603 112+2
Valve Springs....
I would replace the springs, I have just the springs for $129 shipped.
http://www.briantooleyracing.com/660...l-springs.html
I'm going to use the LS7 lifters.
I called patriot today and he said that normally 20-25k is time to replace.
Youre cheaper than them so I'll save that link for when I start buying parts!
Tooley has done hundreds of hours of spintron testing with stock rockers and springs with more open pressure than should be used with stock rockers and it eats the valve stem tips up over time.
