LS2 timing cover difference? Need help
Old Aug 29, 2012 | 06:52 PM
KY Nova's Avatar
Default LS2 timing cover difference? Need help
I'm putting a F1A on my LS2 out of a 06 TBSS in a 71 Nova. I bought a 06 GTO water pump so i could put a LS6 intake on it. The problem, the water pump hits the timing cover and has about a .0050-.0070" gap between it and the block. Is there different covers? If so, what do i need?
Allen
Old Aug 29, 2012 | 07:26 PM
S10xGN's Avatar
If it looks like this:
You'll need to replace it with one that looks like this:
Old Aug 29, 2012 | 07:37 PM
KY Nova's Avatar
Thanks for the time Russ. It looks like the bottom one. I wonder if it's hitting 2 of the bolt heads instead. I could pull them and see, but there would only be a few thousandths gap between the cover and back of the pump.
Old Aug 30, 2012 | 06:52 PM
KY Nova's Avatar
Does anyone know if that is the only 2 cover designs?
Old Aug 30, 2012 | 07:20 PM
S10xGN's Avatar
Are you checking this clearance with the pump gaskets in place? They are metal with rubber seals and are close to 0.100" thick...
