Budget 6.0 build questions
If you wanted to use a different intake it would require a difference in camshaft profile for that intake manifold.
Stock style intake manifolds can't utilize the same ivo and ivc that a single plane can. A stock style intake manifold it is out of breath and won't make peak power anywhere after 6700-6800rpm where as a single plane can make peak power all the way up to 8500rpm+ if wanted.
Ok so Now I have a set of Brand new 821 heads on there way and the 6.0 long block I am going to drop off at the machine shop to have the block cleaned and bd out .30. So what pistions I am going to need to get 11.5 .1?
Wiseco makes a 5cc dome in a 4.030" bore as that is what I was going to get before I went with a 4.065" bore in my 415. Use that piston and mill 2.5cc's off the head to get to 11.5:1 OR use that +5cc dome and a .040 gasket to get to 11.5:1.
That cam has 19.5 degrees of overlap which is close to the amount my cam does that I showed you in my idle clip I posted on the previous page. It will sound close to mine so don't get caught up on the 112LSA. I had to do the 112LSA to actually keep the overlap down some as too much can be a bad thing. You don't want to over-scavenge a stock intake as they have long runners as is and velocity will be higher because of this. Now with the LS3 heads though overlap seems to help port velocity to some extent due to the big by huge intake runner they have and overlap can help with building some port velocity to raise torque production across the board.
I still can't guarantee 500rwhp, but I will say we had a 5th gen here at the shop the other day that had Ai 270cc LS3 heads, Fast 102/92 intake and tb combination, 1x7/8" ARH headers and ARH exhaust with a mid 230's intake duration low 240's exhaust duration camshaft in it and it made 507rwhp and 466rwtq on our eddy current dyno jet which reads a good bit lower than inertia style dyno jet's do.
