Happy with my heads *added flow numbers/stall point
You may need more than just heads to meet your goals. Whats your setup? A cam change may do you good with better flowing heads, and a chance to switch to a better grind as well. That could possibly put you slightly beyond your goals.
I'm guessing this isn't targeted toward me. My expectations aren't numbers, but results at the track.
I figured they would stall around .700 lift as your head ported obviously knew when he was porting them the lift range your cam would be in.
Good job, keep us updated with results.
