VVT tuning with compcams limiter
Once driving I was able to scan with HP tuners a max of 8.2-8.4 degrees advance in the part throttle areas of my tune. I had to change those valvues from the 22 degrees I originally had in there to 8.4 to prevent from getting a cam actuator code. I ended up putting 5 degrees in my WOT 6000 rpm cells which should give me 3 crank degrees (5*2-7) retard at this point.
I found it hard to believe that GM retarded the cam 52 degrees from the factory and thought the numbers (26 max) in my stock tune were in crank degrees. I am pretty sure from all of this they were in cam degrees. Now with only 8.4 cam degrees of retard in part throttle areas I would guess the fuel mileage benifits are mostly gone but the WOT benifits are all still there.
I played with numbers from 4 to 8 in the WOT cells and saw a small difference in power using a virtual dyno program. 4 degrees was apx 5 to 10 hp stronger than 8 up top in the 4 runs I averaged but I would rather do this kind of testing on an actual engine dyno to really dial it in. IF anyone has that info to share it would be nice but I doubt they will.
I can assure you guys that this car will see the dyno ( although probably not this year unless I buy a dyno which I actually have considered and still may do ) but when it does? I'll be posting up my findings.
(I've haven't been able to do a CASE learn on my motor, and I was worried that it might be limiting me too. Although I read CASE is not important, you never know some of the interactions these new GenIV PCMs have.. I suspect CASE isn't enabling because I don't have my brake switch wired in to the E38 PCM.. Purhaps this Winter it'll make the patch list)
mike
Does anyone know what gains in fuel mileage there are with a VVT cam working fully vs not having one at all?? Maybe someone with a stock cam could shut off the VVT in the scanner and do a before and after reading in a somewhat controlled enviornment.
To figure PTV clearance I just measured the valve drop at 10 degrees before TDC with checking springs (or no spring). This is usually when the ex valve is closest to the piston give or take a few degrees. Then I measured the lift at the pushrod only with a dial indicator at 10 degrees before TDC for fully advanced and multiplied that times the rocker ratio and subtracted from the valve drop. To see what it was retarded 22 degrees just rotate the motor to 32 degrees before TDC and measure the lift at the pushrod and do the same math. You could measure it at 62 (52+10) degrees BTDC if you wanted to see what it was at full retard without a blocker.
Assuming 22* (crank deg) cam phasing available, the process for the exhaust clearance would go as follows:
- Install phaser sprung in advanced position (default)
- Measure valve lift at 10*BTDC
- Measure PTV clearance at 10*BTDC by pushing down on the valve
- Rotate the crank to 32* BTDC (10*BTDC +22* phaser travel)
- Measure valve lift at 32* BTDC
- Compare valve lift at 32*BTDC to valve lift at 10*BTDC. Subtract the difference from PTV clearance at 10*BTDC
You could even sweep over a range of crank angles to figure out exactly where your minimum clearance would be for both situations. **** man, that is brilliant. All clearances checked without ever rephasing the cam. Only challenge is understanding the phaser travel, but you could probably do that with a protractor while you're installing the limiter block or do as you did with the compressed air.
Very smart. I'm tempted to repeat my measurements just to see how they compare and also kicking myself for taking apart a perfectly good phaser. Having one of those "why didn't I think of that" moments. Thank you 64c10ls1!
Check cam installed ICL with phaser in advanced position (default) **107 ICL
Assuming it is correct procede (They ground your cam right and sent you one on the correct core)
Remove spring
Turn motor to 8 degrees BTDC (thats what I used)
Measure ex valve drop from seat to piston contact with a dial indicator on stem (no rocker no spring) **.385"
Put the spring back on or hold valve up with cloths pin or checking spring
Install dial indicator on ex pushrod tip (no rocker) and turn motor till your on the base circle Push down on the indicator and set to zero
If you want to check PTV at fully advance then turn motor to 8 BTDC
read indicator **.034 .385 - (.034 x 1.7 = .058) = .327 ptv fully advanced
Turn motor backwards (retarded 22 degrees) to 30 degrees BTDC
Read indicator **.130 .385 - (.130 x 1.7 = .221) = .164 ptv retarded 22 degrees
This assumes the rocker ratio is actually 1.7 at all lifts (close probably)
This assumes the small spring in your dial indicator won't collapse your lifter (it won't)
You don't have to block your lifter this way.
You can do you intake this same way but only in the advanced position and at 8 degrees after TDC **.208 valve drop - (.077 x 1.7 = .131) = .077 ptv Intake fully advanced
Dia 3.294
Gap .246
.246 / (3.294 * 3.14) * 360 = 8.56 degrees
Mike, I also checked it with the block in the wrong chamber and came up with this
Dia 3.294
Gap .213
.213 / (3.294 * 3.14) * 360 = 7.4 degrees
Your intake clearance seems awfully tight though.
Ran it several times to 6500 without issue so far. Normally the auto tranny will shift at 6300.
Comp cams 214/228 114+7 apx .570 lift
Beehive springs and comp pushrods 7.375 (actually measured 7.4 gurrrr)
Maggi 1900 blower with 3.0 in pulley instead of stock 3.3
Stock E85 compatible injectors because they were bigger than the ones in the kit. Need bigger, at least an LS9 injector.
Has 7.5 lbs boost with small pulley, 5.0 with stock pulley.
LS9 Map sensor
Now you got me thread jacking. lol
Dia 3.294
Gap .246
Dia 3.294
Gap .213
Them change their directions from "any" chamber to the chamber
Closest to the pivot. Even then, 8.5 deg is not the 11 deg they're
Advertising.. Class action, class action...
No worries about hijacks, we're still on topic here...
