Pushrods...
Old Oct 9, 2012 | 01:40 AM
trevmust's Avatar
Default Pushrods...
you don't have to change the length unless you change the camshaft right? I'm changing the rocker arms though.
please don't hate on me... I'm a noob...
Old Oct 9, 2012 | 08:04 AM
87silverbullet's Avatar
You change the pushrods anytime there is a change in the heads or block. The length is not changed even with a different camshaft.
If you're changing the rockers I would go ahead and upgrade to some hardened pushrods while you're there.
Old Oct 9, 2012 | 09:09 AM
Sales2@Texas-speed's Avatar
LS1Tech Premium Sponsor
When you change ANYTHING in there it has potential to change the needed pushrod....swapping camshaft, heads, block, gaskets, valves, and yes, even rocker arms can cause the need for a different pushrod. Always measure to be sure!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old Oct 9, 2012 | 10:12 AM
trevmust's Avatar
7.4" are the stock length apparently
Old Oct 9, 2012 | 10:14 AM
Gauge length (how most aftermarket pushrods are measured) of the stock pushrods is about 7.380" or so.
__________________
Old Oct 9, 2012 | 11:26 AM
trevmust's Avatar
oh. okay thanks. Would the comp cams lifters be a good thing to do as well?
Old Oct 9, 2012 | 12:35 PM
You don't have to if the lifters that are in it are fine. People usually do an upgrade to the LS7's. You have to pull the heads to replace them though.
Old Oct 9, 2012 | 01:28 PM
trevmust's Avatar
well I want to turbo the engine eventually. I want to upgrade as many of the easier to break parts as possible. Rocker arms, pushrods, lifters, head bolts.
Old Oct 13, 2012 | 06:45 PM
trevmust's Avatar
if I pull the heads on a crate LS3 will I have to replace the gasket? or is the stock one a steel shim gasket...?
