Reluctor ring runout help! 24x in ls3
Old Oct 20, 2012 | 06:48 PM
allan808's Avatar
Default Reluctor ring runout help! 24x in ls3
What is the Max runout? Mine is at .0265 on one spot. And is runout only measured on the flywheel side? Any and all help pertaining too this issue. How do I accurately check it?
Old Oct 20, 2012 | 07:47 PM
S10xGN's Avatar
I think I remember the spec being 0.010". Guessing your doing a swap, as the LS-3 had a 58x wheel? I'd be concerned with runout viewing the wheel perpendicular to the crank centerline, as that's what the sensor sees. That said, the GM ECM is a bit more tolerant than an MSD box and possibly other aftermarket setups...
Old Oct 20, 2012 | 08:36 PM
allan808's Avatar
Yes I'm doinga swap into an 98 Fbody. Its a new ls3 block.. In my book it says Max is .028 but some engines require .010, I need too make sure its right.
Old Oct 21, 2012 | 04:35 AM
BODUKE's Avatar
That's a good question. I just had my reluctor in my ls3
shortblock changed to a 24x. I had katech change mine out.
Old Oct 21, 2012 | 08:25 AM
G Engines's Avatar
This has become a problem sense gm has sent the machining of this part to mexico, the quality is just not the same as it used to be. Another problem is at higher rpm the rivets are not holding the two parts together and they will separate. LME make a one pice billet wheel it's not the cheapest but it is worth the money.
Old Oct 21, 2012 | 11:09 AM
ramairws6's Avatar
You are correct. The next time my engine comes apart this billet relucter will go in. I already had one of these come apart on me and it's sitting on my fridge in my shop as a conversation piece
Old Oct 21, 2012 | 06:14 PM
allan808's Avatar
Any more info? Sponsors can we get some help?
Old Oct 22, 2012 | 09:20 AM
allan808's Avatar
Decided too go with LME billit wheel, talked too them this morning $180 installed!
