Best Spark Plug for Cam Only LS3
#41
Natureally you can get a little more aggressive with tuneups with colder plugs as well because you don't have to worry as much about creating glow plugs with the colder heat range. Seeing it on the dyno with timing and plug types is my base for using at least a heat range 6 in any LS engine in the 10+ compression ratio that gets regular abuse. Funny thing is my car has ran fastest passes NA at the track with my nitrous plugs.... non projected 8 NGK gasket seat plugs 4554.
In the end do what ya want. Just my .02
#42
