Can anyone help, please!!!!
Old Nov 28, 2012 | 08:18 PM
towerhand's Avatar
Default Can anyone help, please!!!!
Parts list: 02 T/A, M6 trans, 408 iron block, 11.6-1 compression, diamond pistons, callies 4 inch crank, callies rods, Fast 102mm intake, LS3 PRC heads, LS6 lifters, LS6 ported oil pump, 50# Fast injectors, 102mm PTM tb, 85mm truck maf, LS3 rockers with trunion upgrade, camshaft is comp, 612 622 lift, 244 254 duration, 112 lobe seperation, racetronix pump with hotwire kit.
I went and had my car dynoed today and it is busting up between 2 and 3 grand, after 3 it clears but is blowing black smoke out the back, adjusted fuel air ratio all the way to 13.8 but will not clear smoke, also engine peaks at 5200 rpm and levels out but cam is supposed to peak around 6500. I do not know which way to look, camshaft was degreed at 110 and a half, suppose to be 110, but was as close as we could get it. Any suggestions?
Old Nov 28, 2012 | 09:22 PM
Tainted's Avatar
Are you sure all your coil packs are working right?
Old Nov 28, 2012 | 09:43 PM
06X6spdGTO's Avatar
What pushrods are you using and are you sure they are the correct length??? Who installed the cam? Is it degreed in correctly??
Old Nov 28, 2012 | 09:48 PM
litle88's Avatar
What spark plugs are you using?
What are they gapped at?
Also check the wires, and yes check the coil packs and their harnesses.
Old Nov 29, 2012 | 07:21 AM
87silverbullet's Avatar
Check your MAF. What is the gm/s on HPtuners? Unplug it and see what the values do. Had the same thing happen and the MAF went bad causing all kinds of issues. I thing you might want to put this in the PCM diagnostics section also
Old Nov 29, 2012 | 07:34 AM
towerhand's Avatar
MAF is fine, Futral checked everything on the dyno yesterday, all the above mentioned is fine, is it possible that the reluctor is off, it is not throwing any codes. I am going to check and see where the timing is at with a light.
Old Nov 29, 2012 | 08:26 AM
MMWS6's Avatar
I too am curious as to where you set the gap on your plugs and what was the heat you chose for the build on them. I'll toss out there if you are over 40tho close the gap. 11.x:1 can and will cause spark blow out if the gap is not in the 40 range, maybe even tighter
Old Nov 29, 2012 | 08:53 AM
towerhand's Avatar
Gap is .035, NGK TR56
Old Nov 29, 2012 | 11:11 AM
MMWS6's Avatar
Gap sounds good. Seen guys love that plug and others hate it... With what you have I think your plugs are OK. Timing light time it is then, see if your reported is the same as your actual. You using HP Tuners for the tuning job? I'd like to see if torque managemant is messing with you. I don't want to step on your toes, are you tuning yourself or you have a shop doing the tuning?
Old Nov 29, 2012 | 12:31 PM
towerhand's Avatar
HP tuners and Futral in LA was doing the dynotune
Old Nov 29, 2012 | 02:36 PM
MMWS6's Avatar
Do you have the HP program yourself? If so, post a copy in the tuning section with a link to it here
Old Nov 29, 2012 | 02:48 PM
towerhand's Avatar
I dont have it, guess i have a nail biter, i will check with the timing light and genesis this afternoon and post my results.
Old Nov 29, 2012 | 04:16 PM
litle88's Avatar
With that compression in get a tr6 IMHO, or an iridium plug in that heat range.
Old Nov 29, 2012 | 04:18 PM
litle88's Avatar
Can you double check your at dot to dot on your cam? Might be a tooth off? Just brain storming.
Old Nov 30, 2012 | 09:32 PM
towerhand's Avatar
I think i found my problem tonight guys, i was checking my push rod lengths and it appears i am .045 too long. According to my new tuner- builder, i am suppose to get my rocker tightened to 0 lash, and should be able to tighten on down 1 full turn of the bolt, which will put me at .060 preload, but with what i currently have, i can turn 1 and 3/4 turns, which is giving me around .105 preload and is causing the valves to stay cracked and causing reversion.
Old Dec 1, 2012 | 07:54 PM
HOTROD NETWORK's Avatar
What length push rods did you use?Are the heads milled at all?Were you on the base circle of the lobe when setting zero lash?I'm pretty sure one full turn on the rocker is .047 not .060 but I could be wrong.
Old Dec 5, 2012 | 04:58 PM
06X6spdGTO's Avatar
PLEASE SEE MY LAST POST!!!
Your Welcome!
Old Dec 5, 2012 | 08:11 PM
towerhand's Avatar
Yeah, turns out that is not the problem, pullin heads this weekend, but thanks anyway, man
