Pat G or Tony Mamo or anyone else
Guess it kinda depends on overall goals and budget. The aftermarket cathedral stuff produces great results when paired with a FAST intake and other supporting mods which can cause the costs to add up quickly.
Though possibly/probably down in power from the afore mentioned $$$ packages, LS3 head based engines can yield some pretty impressive results with factory based castings and factory based intakes which lowers overall costs significantly.
As one example of many that run quite well, look at the performance of Stanger383 and his stock LS2 shortblock with SDPC LS3 CNC heads.
He has run as fast as 10.15 and 131mph with that combo (in - DA).
His times improved from 10.50's to 10.30's just by basically bolting on the CNC SDPC heads vs stock LS3 heads.
http://forums.corvetteforum.com/c6-t...heads-now.html
http://forums.corvetteforum.com/c6-t...-in-300ds.html
https://ls1tech.com/forums/automatic...-10-15-et.html
http://forums.corvetteforum.com/c6-t...post1582361022
- Stock LS2 shortblock,
- SDPC CNC LS3 heads,
- Ported L76 intake
- 231/240 .617/.613, 114+2.
- LG headers, PTB, CAI,
- 3.42 gears,
- Yank SS4000 converter
All you cathedral head faithful will insist that the LS3 head just won't run very well on a 4" bore, but cars like Stanger383's just go ahead and prove that it is possible to produce great results even with all that atrocious valve shrouding and port volume.![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
![Hail](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_hail.gif)
- Ported L76 intake
- 3.42 gears,
![](http://i1250.photobucket.com/albums/hh525/stanger383/Photo12.jpg)
#32
square port heads all the way! cross section is king! Look at some of the small bore ones and stick with them.. valve shrouding is an issue but tends only to hurt low lift flow, so stick more lift in it and faster ramps
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
#33
Yet, the L76 4.000 bore is in a G8, a 4000lb street car. Alot of power has been made with them no matter street car or more race oriented on a 4.000 bore.
Yes the LS3s have 16 more cubes, but you often see cam only engines making high 400s easily. A cam only L76 G8 is usually low-mid 400s. It takes a pretty big cam and headwork to make a 364 with 4.000 bore hit close to 500 with stock L92 heads.
#34
Yall can do what you want, bbut I promise these past 3 months since I got this 408 I have read thousands of threads from all different sites, talked to many sponsors on the phone and local people. ls3 heads on small bores is NOT the way to go. If you are looking for 450-475rwhp on a budget, then by all means yes! they are a GREAT budget head! HOWEVER if you want a very well rounded combo with power everywhere without sacrificing PTV clearance amoung other things then you should stay cathedral.
Now if you start talking small bore style ls3 heads thats a whole other ball game.
#36
thats only going to add insult to injury for small bores.
GM L92 castings. West Coast Cylinder Heads (ProHeads.com) Stage 2 on the 403 and Stage 3 on the 427.
The bottom line is the 403 with a ported L76 intake. I couldn't find the final chart for the 403 but it ended up at 530RW on 2 different DJ's.
The top line is the 427 with a FAST 102. Both builds well optimized and extremely mild. The 403 was with a 230-240 cam and the 427 runs a 234-242. I don't think you'll see those number without going much bigger with on the cam and then you'll loose on the bottom. CR on both is 11.3 to 11.4. Both builds so mild your mother could drive them with a 6 speed and 3.90's.
Had the car out today in Washington, DC rush hour and it's no more difficult to drive in that crap than a stocker.
The large runner/valve LS3 heads kill low end, yada, yada, yada theory should go the way of "the earth is flat" thinking.
![](http://i54.photobucket.com/albums/g93/WKMCD/427DJCorrected1.jpg)
![](http://i54.photobucket.com/albums/g93/WKMCD/VSEngine5.jpg)
![](http://i54.photobucket.com/albums/g93/WKMCD/corvettepicphil1.jpg)
#37
Super Hulk Smash
Well rounded - power everywhere???
This isn't rocket science. It's the same way you cam any high flow head.
Folks here are all so used to camming in a way that acts like a crutch for stock LS1 heads. The LS1 has pitiful compression and weak I/E ratio. Things like the T-Rex are born to create power within those confines with huge overlap and very tight LSA/ICL to get dynamic compression up within a very narrow RPM window. Well, that thinking needs to go the way of the dinosaur for LS3 and any high flow cathedral port offering.
#38
