Link-bar Lifters - get in here
Lunati spring kit, big thick manton PR, stock rockers
FTI cam
Is not chewing up springs or any other parts.
Tim
As far as the TFS im still torn, the prc matches my budget better and it seems like the results between the two can be split between a curly **** hair just about.
Just kidding, I love you guys...no homo.
I'd still wait and get the TFS heads. Lol
i think im past that age by a little bit now, either way youd be hard pressed to get me to drink. IMO I'd go TFS w/ powder metal guides and stock rockers with a 3/8 pushrod. The pushrod holes in the TFS heads are huge! Also remember different lifters will be different heights so don't order your pushrods until you get the lifters in the engine and cylinder heads on to accurately check pushrod length. The Morels that I have didn't have but ~.080" total travel so that leaves little room for error in pushrod length. Stock LS7's had ~.200".
If you start crashing the lifter on the lobe the SLR is going to fail just like any other cast body lifter.
Tim
Finslly made up my mind on heads, PRC LS3 small bore, just unsure if i should go 250 255 or 260cc. I think the 255 have the best numbers for me
