Cam Question
Old Dec 13, 2012 | 11:49 PM
99JoeT/A's Avatar
Default Cam Question
Hey guys just got a quick question. Is it possible to run a texas speed MS3 or MS4 cam with out changing anything other than a tune and a stall? any input will be helpful Thanks.
Old Dec 14, 2012 | 12:21 AM
35th SS's Avatar
what heads are you running?p/v clearance check to make sure.
Old Dec 17, 2012 | 12:29 PM
99JoeT/A's Avatar
Default heads
i still just have the stock heads i think 823? is that right? on a 99 ls1
Old Dec 17, 2012 | 12:34 PM
elephantrider's Avatar
you'd be leavning alot of power on the table with no
accomodating heads, for those cams.
Old Dec 18, 2012 | 04:18 PM
99JoeT/A's Avatar
Default cam
Im planning on getting different heads but for right now im just kind of on a budget and im lookin for a good power boost untill i can get the heads and everything too.
Old Dec 18, 2012 | 04:23 PM
JakeFusion's Avatar
Super Hulk Smash
What mods do you have? I would hope at least a lid, headers, ypipe/catback or duals, and a stall of some kind. If you have all that, all you'd need is the cam kit from TSP and a tune unless you have like a 2500 stall. But 3200+ will work with those cams (but might not be optimal).
Old Dec 20, 2012 | 03:01 PM
99JoeT/A's Avatar
Default cam
as of right now i have LTs no cats SLP catback and a Volant CAI. im actually workin on gettin a set of 243 heads right now then ill buy the cam. will i need to change any thing on the 243s to run them with a MS3 or MS4 cam?
Old Dec 20, 2012 | 03:30 PM
badassracing's Avatar
Yes you can just check ptv clearance. With that said, thats probably not the best cam for that setup and you wont be able to get the full advantage of the cam without the full array of bolt ons...heads, intake, gears, stall, more compression etc.
Old Dec 20, 2012 | 05:25 PM
99JoeT/A's Avatar
Default cam
what would be a better cam, im planning on a stall and 3.73 gears this summer and an ls6 intake
Old Dec 20, 2012 | 06:36 PM
towerhand's Avatar
I had a 00 ss Camaro with similiar setup. LS6 heads, ported and polished LS6 oil pump,3000 stall, MS3 cam, stock injectors, LS6 intake, and 3.73 gears, it ran 6.83 threw the 1/8 on motor and 6.38 on spray, sweet setup but beware and change the lifters to LS7 the first time so you dont have to do it twice.
Old Dec 20, 2012 | 08:43 PM
99JoeT/A's Avatar
Default cam
ok thanks alot. what kind of power was ur car makin?
Old Dec 21, 2012 | 08:51 AM
towerhand's Avatar
do not really know, had the car street tuned, not on a dyno, but it was a beast for a street car. you shouldnt have any PTV problems with this setup, i never did and initially i had stock LS1 heads and changed the springs to match cam and that spray was on a 100 shot. I did not put on the LS6 heads until i changed the lifters, because they were collapsing.
Old Dec 21, 2012 | 09:59 AM
im running the ms3 cam, matching 241 heads ( fully worked ), with long tubes, etc..
making 415 to the wheel, on my ls1 goat.
Old Dec 22, 2012 | 12:37 AM
99JoeT/A's Avatar
Default cam
Thanks alot for all the advice guys
