LQ4 options
Old Feb 5, 2013 | 09:44 AM
Tainted's Avatar
the fuel rail is the same as far as I know. i dont know if the injectors are any bigger or not either.
Old Feb 5, 2013 | 10:00 AM
oscs's Avatar
That would great if I could reuse the fuel rail/throttle body and just upgrade the injectors.
Old Feb 5, 2013 | 10:05 AM
Tainted's Avatar
you can for sure reuse your throttle body and rails. you would want a bigger injector anyway, probably a 39-42lb injector
Old Feb 5, 2013 | 10:14 AM
oscs's Avatar
Any idea where to get an injector of that size? Any other factory compatible injectors or best to source aftermarket. Also will all my sensors from the ls1 bolt up to the ls6 intake?
Old Feb 5, 2013 | 10:18 AM
Tainted's Avatar
all your sensor will carry over. I beleive you can make the ls2/3 injectors work with spacers and maybe a pigtail connector...? Im not certain on that part. If not though, theres plenty of injectors on the market.
the goal here is a general rule of thumb is you dont run your injectors more than 80% duty cycle
Old Feb 5, 2013 | 11:18 AM
lemons12's Avatar
Ls3s are 42#..
You aren't hitting even 450rw with a budget setup.
Old Feb 5, 2013 | 11:23 AM
lemons12's Avatar
Not to be rude... You need to research for hours before you buy every part.
Old Feb 5, 2013 | 11:31 AM
Tainted's Avatar
Originally Posted by lemons12
Ls3s are 42#..
Corrected, i thought they were 39#
I think he can get 450 with some good ported heads and a decent cam as long as the intake is decent.
Some AI 226s, healthy cam, fast 92mm I think he could do it, and not break the bank with a little help from the for sale section
Old Feb 5, 2013 | 11:35 AM
lemons12's Avatar
Ai is going to be 1200+.. The valve train pump chain etc with the cam over 1000.. Fast setup 1000.. And there is plenty of small **** that adds up.*phone
Old Feb 5, 2013 | 11:38 AM
Tainted's Avatar
Hey you gotta pay to play! I would hope someone would expect to pay around $3000 assuming they can do the work. And that includes some smart shopping. I was thinking he could pick up a used FAST and maybe even score some heads.
Thats budget to me, ive got almost $2600 just in heads
Old Feb 5, 2013 | 11:54 AM
lemons12's Avatar
Im right there with you.. Most people want 450+rw and want to buy some stg 1 ls6 heads, 228r, and an ls6 intake.. Cake and eat it too.
Old Feb 5, 2013 | 12:06 PM
  #32
Tainted's Avatar
I see the older fast 90 and the 92 sell for 5-700$ depending on if it was ported out from time to time. Thats really not bad considering the $850+ new price
Old Feb 5, 2013 | 12:12 PM
  #33
oscs's Avatar
The car already has a TSP 228r cam in it. From what I've been reading the ls6 flows pretty damn good. Matched with some bigger Injectors and a good flowing set of 243's what else would be needed? (Little stuff)
Old Feb 5, 2013 | 12:21 PM
  #34
Tainted's Avatar
The ls6 flows good vs the ls1 intake. Compare the ls6 to the fast and the difference is huge.
With good port work on the ls6 heads, and measure ptv clearance and mill them as much as you can accordingly. That should be a nice bump in compression.
Old Feb 5, 2013 | 01:00 PM
  #35
oscs's Avatar
Ill look into the fast (plenty here in houston locally) PM'd a couple guys with some 243's with AI porting. Ill probably changing my leaky injectors this weekend so I need to find something that will work fairly quickly.
Old Feb 5, 2013 | 01:07 PM
  #36
Tainted's Avatar
search to see fi the ls3 can be run with the FAST intake. im pretty sure they can, but youre gonna need a couple things.
Old Feb 5, 2013 | 01:39 PM
  #37
lemons12's Avatar
The ls3 can run a fast.. Imo it isn't worth the money. 5hp gain over an ls3 intake in most cases.
Stock ls3 or sheet imo.
Old Feb 5, 2013 | 02:16 PM
  #38
oscs's Avatar
When you guys say ls3 you are you all referring to the heads or injection system?
Old Feb 5, 2013 | 02:20 PM
  #39
Tainted's Avatar
I was refering to the cathedral fast being able to use ls3 injectors
Old Feb 5, 2013 | 02:25 PM
  #40
oscs's Avatar
If I remember correctly the LS3 intake will not work with the 243 heads correct?
