How are the 454's (and bigger) holding up ?
Im at 40,000 miles in my 440 Darton.
Valvetrain was not set up right first up from vendor. Cam got trashed.
Rebuilt better and going ok so far.
Goal is 200,000 with any luck.
It eats a bit of oil. I dont think the hone job or piston to bore setup was done right. But its tolerable. Next time, Id go 427 to keep parts off the shelf. But no hesitation in doing a stroker again. OEM config..
Sorry cant see sigs in mobile view.
If you would be so kind, can you post what the resleeve cost including machine work and sleeves?
I'm wanting to go this route. I already have cnc ported ls3 heads and intake. Should make a killer setup IMO
For you and other's not experiencing oil consumption or, I assume, excessive blowby, what were your rings gapped to and what pistons are you using?
Do you need someone to break in the motor for you? Just kidding....not really...lol
#32
We have a 454 LSx short-block in stock with a seasoned block & priced very attractively! It's a 4.185" bore & 4.125 stroke.
We typically do about a dozen of these engines a year with good results.
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Jason
2005 Twin Turbo C6
