tuning please help !!!
Old Feb 17, 2013 | 04:30 PM
wrxmaster07's Avatar
Default tuning please help !!!
i recently purchased a 2000 ws6 and it has a fast 102mm nick Williams 102 tb ls2 heads 180 degree thermostat longtube headers and a mail order tune. the guy said when he had it tuned they pulled as much timing as they could because he wouldn't be driving the car a lot, he said that I need a 160 degree thermostat for the car to run and idle right. when I first start the car up, it wont stay running unless I keep my foot on the gas. but when I start driving it it is fine for awhile until I come to a stop then the idle bounces up and down and eventually stalls. do u thihk the thermostat will solve the problem or is it in the tune
Old Feb 17, 2013 | 07:27 PM
ramairws6's Avatar
Hahaha......NO!
Old Feb 17, 2013 | 08:13 PM
LS1MCSS's Avatar
You don't need a 160 thermostat. You need a tune and you need to have a mod move this to the tuning section.
Old Feb 17, 2013 | 11:18 PM
98cobrakiller's Avatar
is it a automatic
Old Feb 17, 2013 | 11:19 PM
if its a automatic and it has a cam you need a stall converter. and ses lights on
Old Feb 17, 2013 | 11:41 PM
It's a 6 speed
Old Feb 18, 2013 | 02:06 AM
Gunslinger09's Avatar
You need to get it to somebody that knows what they are doing to tune it. The T-Stat won't have that kind of effect on the car.
Old Feb 18, 2013 | 07:43 AM
MMWS6's Avatar
Nope, a t-stat will not aid your cause there. Sounds like your base runnng air flow tables and timing are out of wack... but just a guess. A mainifold leak or and exhaust leak could cause something like this as well. If mechanically you are sound, then you need to have it tuned properly
Old Feb 18, 2013 | 01:20 PM
ok thanks guys that's what I thought too but just figured id ask around first
