Melling 10296 idles 50psi @ 205*F, increases psi with rpm.. how much is too much?
I'd much rather have high oil pressure vs. low, but the pressure readings with the new melling 10296 are so much higher than my old stock pump/motor that I just wanted to double check what pressure is ok.
I'm still running Joe Gibbs BR30 break in oil, and the oil has a cold idle around 60psi, then drops to ~50psi hot (205*F @ idle). As RPMs increase, the pressure increases, and I'm just curious if there is a 'max' I should be worried about exceeding. I'm pretty sure it'll max out the stock gauge which only reads up to 80psi.
I'm curious what you figure out here. Everyone seems to run the 10296 but my builder told me to run the 10295 and uses that on all his builds. I haven't run my new engine yet but will definitely be watching the pressure when I do next week.
I say 75 psi is safe but above 80 will likely scuff the bearings, a friend seen 120 psi on the dyno, that will likely never happen to me sense i clean up the pressure bleed port and seen it very compromised with overcasting every time i look into 'em.
Good to know. I'm tuning the car this weekend, so it'll be the first time it sees redline, so I could very well see that much pressure (not sure if I'd know on the stock gauge though, maybe I can log it and the table won't max at 80psi like the gauge does?)
I'm planning to run Joe Gibbs LS30 oil, so it will be on the lighter side compared to what some people run
The 10295 is high pressure, the 10296 is high pressure/high volume. I think the 10296 also comes with a regular spring to make it regular pressure/high volume.
The 10295 came with an extra spring also. My builder sent me a ported pump and I will also be running Joe Gibbs... break in oil and then LS30.
Buddy of mine sees 95-100 psi at 7500-8000 and his engine is still purring like a kitten. A pissed off turboed kitten but no shaving in the oil and everything looked great the last tear down.
He took that pump out rite away.
Any more than 80 psi is a lot of pressure, bearing babbitt is not that hard, you need to know what you are looking for to find scuff bearings, in the flip side, i rather have scuff bearings than low pressure and worrying. 90 psi is where i drow the line.
My clearances are .0025. Maybe that is why I was recommended the 10295 high pressure pump.
Super Hulk Smash
Pressure you see is directly related to the bearing clearance. A high flow pump simply moves more oil and depends on the bearing clearance for the pressure you see on your gauge. The "high pressure" pumps are related to the bypass spring. The 10295 is no where near as thick as the 10296, because the gerotor in the 10296 is like 23% larger and thus moves a lot more oil.
The only way to add pressure is to increase oil volume for a given clearance or change the clearances.
