Max effort LS7 Cam suggestions needed
Old May 11, 2013 | 12:22 PM
Slowhawk's Avatar
LS1Tech Sponsor
Still wondering how people hit 600rw cam only on those. An intake, header, LS7 makes 475-490rwhp on my dyno. Most cam cars are 525-555rw depending on cam size.
QM600 makes 555-560rwhp but a huge dip in the low rpm area, nice pull 5000+.
Must have a crappy dyno.
Old May 13, 2013 | 03:46 PM
ls1CANTU's Avatar
Originally Posted by gto_ua
I have curtis 256/268 cam in my LS7 and happy with it.
you should run 25x/26x 115lsa cam
Originally Posted by Brian Tooley
We pulled the Black Widow out of my buddies car and installed something a little more aggressive. He reset the C6 Z06 H/C record yesterday running 9.86 @ 140.8 at 2000 ft D/A and he was .04 off his best 60'. With better air and a better 60' he's hoping for 9.70's. Cam was in the 24X/26X range.
PM sent
Old May 13, 2013 | 07:18 PM
John B's Avatar
Moderator
What kind of springs are you guys running on these solid roller set-ups with stock casting heads?
I'm running PAC 1.55" dia.
Old May 13, 2013 | 07:33 PM
Ryne @ CMS's Avatar
LS1TECH Sponsor
your dyno sucks bro!!!!!
Old May 14, 2013 | 08:54 AM
Sales@Tick's Avatar
Did that require any machining of the valve spring pocket to accommodate?
Old May 14, 2013 | 09:40 AM
Alvin@PCMofNC's Avatar
LS1Tech Sponsor
We have the same results. Add heads/ decked and they will make 600 rwhp but to be honestly I would rather choose the cams that make 530-540 rwhp. They are a lot more fun and don't give up that freight train torque down low that a LS7 has.
__________________
See what's in our shop on Facebook! Customer Build Blogs!
www.pcmofnc.com
Performance Installs - Dyno Tuning - Custom Camshafts & Valvetrain - Remote HPtuners Tuning - Mail Order Tuning & Sales
704-307-4227
Old May 14, 2013 | 06:37 PM
John B's Avatar
Moderator
Yes, special machining and then shimming.
Old May 16, 2013 | 01:37 PM
Pumba's Avatar
I would like to suggest that before you talk to a camshaft manufacturer or a speed shop you go to the Wallace Racing website and run their Intake Port Mach Index Calculator. - http://www.wallaceracing.com/machcalc.php
Input your piston diameter, intake valve diameter, peak engine rpms, crankshaft stroke, and a valve lift number into the Intake Port Mach Index calculator. Keep adjusting the valve lift number until you achieve a Intake Port Mach number of .50.
Take that lift number and ask your camshaft supplier to build you a cam with that lift thru the LS7's 1.8:1 rocker arms.
In addition, if you really want the best package and you are not concerned with street usage, have the engine built with .927" solid roller lifters, instead of the .842" hydraulic roller lifters that come stock with the LS7. Isky's lifter bushings - KLV-937 and solid roller lifters - 937K150EZMAX. Your springs should come from CV Products and they are made by PSI - #PSICT1572ML-TC.
Good luck with your decision.
Old May 16, 2013 | 01:51 PM
Pumba's Avatar
Cam only Z06 in Sweden getting it done with 606 RWHP!
Brain,
I am not trying to pick a fight.
I am trying to understand what the DIN correction method is? Also, does DIN use the same barometric, humidity, and temperature correction factors as SAE J1995? SAE J1995 has been used by the OEM automotive manufacturers since 1990 for measuring GROSS ENGINE POWER.
Thanks.
Old May 16, 2013 | 03:45 PM
Brian Tooley Racing's Avatar
Very good catch there. The DIN correction factors are not the same as SAE. DIN corrected numbers are not as high as STD corrected, but they are higher than SAE corrected.
He's in Europe, and they may use DIN as their normal correction.
I think it's all relative, the car gained 160 rwhp with a cam, headers and a Fast 102, which seems like a pretty good gain to me. Especially considering in back to back testing we didn't find any peak HP gains with the Fast 102, only average power gains.
Old May 28, 2013 | 06:57 PM
z0vette's Avatar
Cam only 600rwhp!!
The meanest ls7 cam I have seen and tried without touching the heads was the Striker
It was a bad a.. Cam and it made 572rwhp with full bolt on's and fast intake
I wonder how do people hit 600rwhp without touching the heads?
I want such a cam
Old May 28, 2013 | 07:52 PM
  #32
Blackpanther99's Avatar
Talk about reputable people posting on here. Very nice info.
Old May 28, 2013 | 08:25 PM
  #33
Sales@Tick's Avatar
I have a cam coming out soon to compete with the striker like cams out there. It will be larger than the ls7 polluter.
Old May 28, 2013 | 08:34 PM
  #34
Turbo2L's Avatar
Well hurry up! I'm picking up the Z this weekend.
Old May 28, 2013 | 08:54 PM
  #35
z0vette's Avatar
The striker was an overall cam, very strong mod range TQ and peaked like hell up top.
I have tried a lot if huge cams and ended up disappointed due to the weak power under the curve
Am waiting for your cams Martin ;-)
Old May 29, 2013 | 05:29 PM
  #36
Sales@Tick's Avatar
Patience grasshopper, patience.
I've compared the valve events from the Striker cam to our new LS7 Saturday Night Special Stage 3 TorqueMAX cam and the LS7 SNS Stage 3 should create more torque under the curve due to it's earlier closing intake valve event.
We shall see soon!
Old May 29, 2013 | 05:56 PM
  #37
lil john's Avatar
Oh man you've got it .........loook at who's on this thread....Can 600rwhp+ be coming for the LT....?
Old May 30, 2013 | 09:34 AM
  #38
Sales@Tick's Avatar
This is next on my list of "to do" items. We will not be the first to market with a LT camshaft unfortunately, but we will have some eventually.
Old May 30, 2013 | 09:57 AM
  #39
Cam only 600rwhp!!
I want such a cam
I just had another shop up in NJ break 600 rwhp with my Stg IV cam with minimal head work. I'm trying to get a dyno graph now. These cams are in stock and ship same day if ordered before 4pm eastern time.
Old May 30, 2013 | 12:42 PM
  #40
wesam's Avatar
Brian What cam size is this ?
I ordered Mast 305 LS7 heads will this cam work will with those heads or you suggest special cam ?
