Max effort LS7 Cam suggestions needed
What wall thickness are you using with the 7/16 push rods and are you using restrictor holes?
My pushrods are made by TREND. They are 0.125" wall thickness. No they do not have restrictors. I am using JESEL rocker arms:
Also, we had to machine a notch in the JESEL rocker arm stand at each intake pushrod for clearance. Note the notch in the stand just above the black ARP bolt head:
With 0.750" of lift at the valve the entire system works flawlessly.
I like to spend the money once and do it right, have fun, and no worries.
Congrats Pumba.
Thanks for the generous comments. Enjoy you car!
The smaller the port volume and valve diameters are, the longer the port will exhibit forward flow during the intake cycle (compression stroke), and vice versa. Larger ports and valves will exhibit less velocity, so therefore the forward flow of air will stop sooner in the cycle, which requires closing the intake valve sooner as to not loose too much average power.
It's difficult to gain top end power using larger heads on a engine when using a long runner EFI intake like the stock LS7 or Fast, but it's very easy to lose low end torque as the heads get larger.
If larger heads were the key to making more power, then all LS3 and LS7 heads would make more power than all of the cathedral port heads. But when you look at back to back head testing like the Hot Rod cathedral port head shootout, you see the largest heads did not make the most power.
ARH 1-7/8 with ORX
Stock axle back mufflers w/ flaps open
BTR St4 Cam
Ferrea Stainless exhaust valves (just dropped in, no cylinder head work period)
BTR Platium Spring Kit
Everything else was left bone stock, air intake, filter and all.
On my Dyno Dynamics it made 507.8rwhp and peaked at 68-6900 and carried it. I'll get a graph later on to see.
Sounds like a low dyno number but the fastest NA C6Z with H/C/I setup only made 519rwhp here and went 141mph. So that tells me the WCCH st2 port job on heads and the port matched FAST102 intake did little to nothing for these SBE combos.
We started with a LS7 Polluter cam, which is similar to Brian's Stage 4, but has less intake duration and slightly less overlap. Polluter cam has a 49 IVC event. Peaks at 6400, carries to 7000rpm easily.
With milled LS7 heads and 12:1 it made 582rwhp.
We went to an even larger custom cam, of 250/262 111lsa with an IVC event of 52 and 36 degrees of overlap and it picked up 22rwhp and 24rwtq.
Same car went 150mph in the standing half mile. Other H/C/I LS7 C6's at the same event were going 152-153 with 40 years of wind tunnel testing, 40 years of aerodynamics advancements and much lighter curb weights.
I'd say that's pretty good.
On CF, WCCH is the hot ticket for stock castings, and their port work, guide replacement and new exhaust valves is pretty much the same cost as a nice set of aftermarket heads.
I would imagine this is how they're coming to such a statement or conclusion.
Look at some of Joe Shermans buildups he shows plenty of examples. We work closely with many of the LSx shops through out the U.S. to achieve results.
Brian Tooley is pretty high up on the food chain when it comes to cylinder head/cam shaft work/selection. I'd invest in a phone call to Brian.
If you need ARHeaders please give us a call at the shop or better yet, BTR is also an ARH dealer.
Steve
We order all of our Headers in through Brian and want to thank you for the quality work you guys put into your products! In my experience with all the dyno tuning the ARH headers perform all the time!
Stock bottom end C6 Z06(other than pistons for nitrous),worked over production heads,cam,exhaust,FAST intake and he's flyin' !!
Would there be an advantage to using the RHS Pro Elite raised runner LS7 head with a custom ground cam or are they more suited for use with a 4 barrel style intake/tunnel ram intake and not the F.A.S.T./OEM style intake manifolds? Supposed to work with OEM or F.A.S.T. intakes.
Last edited by weldermike27408; Dec 23, 2013 at 08:14 PM. Reason: found build info
