Lifters?!? CTS VR or LS7?!?
Old Apr 25, 2013 | 08:29 PM
Realcanuk's Avatar
Originally Posted by Dyno Junkie
I'm using the factory LS3 lifters that came in the unopened engine with a Comp Cam. 231 239 .617 .624 113.
I believe LS3 and LS7 lifters use the same part number.
Old Apr 25, 2013 | 09:44 PM
Jadedbird's Avatar
Ls3 and ls7 lifters are the same
Check the gm part number catalog
Old Apr 26, 2013 | 02:53 AM
King Nothing's Avatar
I can see if you are building a all out drag engine, yeah spend money on lifters. But something that isn't spending it's life in the 3000-7000rpm range should be fine with ls7 or SLR lifters and the plastic trays. Use a torque wrench and you should be fine IMO I laugh at people who say "i just snug it up it should be fine" it's pretty obvious what you don't do for a living
Old Apr 26, 2013 | 04:45 AM
ls1 1990 VN's Avatar
I've had no problems with the caddy race lifters.
Old Feb 11, 2021 | 02:31 AM
Jason ball's Avatar
I am building a turbo LS3 and I got a set of the
88958689 or ctsvr lifters but I can't find anything about the plunger travel or the preload I need to set so I been stuck on getting push rods....I got a ls3 Trickflow genx 255 heads and the ctsvr lifters I can't figure out my preload please help
Old Feb 11, 2021 | 01:52 PM
Minimum of .035 to max of .100 preload. Basically same lifter as Johnson 2110.
Old Feb 11, 2021 | 02:10 PM
Jason ball's Avatar
Default Got you
Thank you I really appreciate it I've been searching for since before the corona crap and no one were selling them it seems like people have them in stock now really do appreciate it
Old Feb 11, 2021 | 02:13 PM
No problem. I’d shoot for around .060 myself with those lifters.
Old Feb 12, 2021 | 08:53 AM
GavinFED's Avatar
People that run ls7 lifters or say they've always worked for them are the same type of people that are like "mY lS7 hEaDs ArE fInE nO nEeD tO rEbUiLd ThEm!"
Just get some johnson lifters and never look back.
Old Feb 18, 2021 | 11:43 AM
grinder11's Avatar
I bought some of these way back in 2010. There were some problems with the early versions. I never ran them, and wouldn't if I got a set for free. Two reasons why I wouldn't run them, and why I took them back;
#1: Being a Tool & Diemaker for over 30 years (in 2010) at the time, I measure EVERYTHING that goes into my engines. The Caddy lifters, all 16, measured, 001" SMALLER on the O.D. (outside diameter) than the standard LS lifters that were already in my engine, and those lifters had 30,000 miles on them!!!!
#2: I called at least 6 of the top engine builders in the country at that time, Lingenfelters, Texas Speed, Golen, LME, I forget the rest of them, and asked what lifter preload they recommended. What I DO remember is I called 6 different places, and got 6 different answers!!! Sorry, they measured undersized compared to the stock ones, and I got the impression that either nobody knew what the Hell they were talking about, or it was a tighter kept secret than the location of the Holy Grail. So I went with LS7 lifters, and I've never had any problems. If you're not racing at higher than 6,300-6,400 rpm, the Caddy lifters will make no difference, except on your bank balance. Hope this helps....
Old Aug 5, 2021 | 12:54 PM
smokeshow's Avatar
That's pretty short sighted for someone representing a company that has 'engineered development' in its title. Any engineer worth their salt knows that it always boils down to the requirements - and if your requirements are within the capabilities of a part's/combination's specs, then you'll have no issues running them. I could throw a greased up iron slug down the the lifter bore if all I wanted to do was get it to start just one time. All. In. The. Requirements. Have care what you say. The industry professionals are watching
