Off the shelf pistons for a 3.75" stroke
My goal is whatever I can make with E85 and an upgraded Ti, 800 to 1000 WHP. Anyone know of 11 or so CR, off the shelf pistons that will work for that?
Thanks!
Thanks!
Deck Height
Rod length
Crank stroke
Piston pin Height
And see if there's a Rod combination that works with Any Aftermarket OTB piston and a Given Set deck Height.
Rules of math possibly can work without the Use of A Custom piston.
Longer Rods 👍 do the math with a Piston height using a 4.125 or 4.100 - 4.00 stroke Then adjust available Rod Lengths to get Close to your Deck height
Example of 9.225 to 9.235 are common Deck height numbers.
If you Know your Deck height do the Math 😏
Off the Shelf piston not intended for ...may work
I got a reply from JE Pistons;"We can make the piston close to what you are asking based on the shelf ULTRA piston. Closest configuration is a flat top which should put you right at 11- 1 if you use 68 cc heads and a 0.040” gasket and zero deck.
I would use 361713 as reference and make a new set based on your pin height you need (1.240” ) . Cost is $1273.19 / set, rings (jg31f8-4125-2) are $225.86. You will get all features same as the part number. I assumed a 6.125” connecting rod with 0.927” pin diameter.
All parts are FOB Mentor OH, freight and taxes are not included.
Lead time for this project at current state is 4-5 weeks."
I can measure the deck height when I get the block and go from there but it looks as though JE has a solution.
Molnar makes Power Adder rods in 6.125", 6.2" and 6.3".
There are a couple of ways to go. One way or another I can get there.
Are there other off the shelf pistons that have a similar (or better) feature set as the JE Pistons Ultra's?
http://www.wallaceracing.com/Calc-Deck-Height.php
https://auto.jepistons.com/blog/diff...nk-for-your-ls
I've read that and Have Heard this Yrs ago
On just the 4 inch crank 😂🤣
I bypass that Notion as When and if one Has A Correctly Made Piston with a good tapered bottom of the Sleeve cylinder I hear and Know of Guys getting Many Miles. Old Interweb Truth's and MF'ers not Knowing how to do a Bore correctly.
Also know and Hear if one goes Larger on stroke such as 4.100 to 4.125 in a Factory Block it may have a Little consumption but a Great Piston design HELPS. Don't forget someone Who Knows what there doing. KCS went with a 4.25 stroke Lq4 Lmao. .just don't spin it All crazy keeping the RINGS IN THE PISTONS @ THE bottom of the bore along with Piston Speed.
Quote In my own Words from knowing and Reading
Erik K.
Ask that guy in the post What's the availability of Pistons @ Various Compressions using a 3.90 crank better Said:
a on the shelf Piston from Various Manufacturers
Dude tries to get me with some old Non being able to build or Machine a block Correctly 🐂💩
But what I said is A Known......
Given the question of Asking how Many 383/402/408/416/418's using any of the Various factory blocks combinations listed Above that use a 4 in arm/Crank having Problems with Pistons with a Good/Knowledgeable Finished cylinder Bore. 👍
Piston design and Ring Technology has made the Old Wives tail of Oil consumption and it's Associated problems using a 4 inch crank Irrelevant.
