Off the shelf pistons for a 3.75" stroke
Interesting discussion. I learned a lot. Thanks!
I came back to post that a 4" stroke might be the better way, especially since there are so many 'standard' parts for that configuration.
My concern was not about sleeve length though, it was about matching the displacement to the supercharger, that it might match up better to a smaller (than 427) displacement. It is a Ti with a billet impeller that is a little more aggressive than the cast impeller from Vortech and has H\D ceramic bearings.
As far as stroke and sleeve length, I found this posted by Steve from RED.
"The LS2 and LS6 blocks have a sleeve length of 5.400". The LS7 has a sleeve length (to the tang) of 5.900".
I had Darton lengthen all the wet and dry sleeves to 5.800". The original designs were 5.675" which were good for 4" stroke or 4.125" stroke using a short skirt piston design. The 5.800" sleeve will accomodate(sp) 4.250" strokes."
Handy link to thread
The sleeves I am getting put in are 5.8" and 4.110 ID.
The following users liked this post:
KCS (08-06-2021)
