Lifters?!? CTS VR or LS7?!?
Old Apr 24, 2013 | 12:26 AM
Jadedbird's Avatar
Default Lifters?!? CTS VR or LS7?!?
Okay so i have read 100s of threads...
Some say the ctsv lifters are junk... Others have never had a problem...
Some say ls7 are more that enough to suffice... And they are half the price
the cam i may use is a 232/236 .600/.600 113lsa with dual springs. The rev limited will be kept the same (more than likely)
What do ya think?
Old Apr 24, 2013 | 12:36 AM
JakeFusion's Avatar
Super Hulk Smash
Morels. I don't even play around with **** anymore.
Old Apr 24, 2013 | 05:50 AM
C5natie's Avatar
Ive never had an issue with LS7's. Have them in my LS3 now with a 231/236 .641/.615 cam. If I upgrade the heads I am thinking of link bar lifters just for peace of mind. I think the LS7's do handle most street car duties just fine. All in the valvetrain geometry and springs pressures IMO.
Old Apr 24, 2013 | 08:40 AM
ramairws6's Avatar
You'll be fine with the LS7 lifters. I would stay away from the Caddy lifters all together. I had a set without issue but they were a lot more noisey for sure. Also they are not as robust in most areas and thats why they are lighter for the higher sustained revs...
Old Apr 24, 2013 | 09:31 AM
Scoggin Dickey's Avatar
LS1TECH & Trucks Sponsor
LS7 lifters.
Also: https://sdparts.com/details/scoggin-...-center/sdlslk
or just lifters: https://sdparts.com/details/gm-perfo...parts/12499225
But I'd replace the guides too unless they are pretty low mileage.
__________________
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
Old Apr 24, 2013 | 10:01 AM
Jadedbird's Avatar
Originally Posted by Scoggin Dickey
LS7 lifters.
Im actually ordering te ls1 conversion kit (and some other parts) from you guys so ill have new guides.
Does anyone drill holes in the guides to help with oil flow?
A guy did it on his ls3/l99
Old Apr 24, 2013 | 10:48 AM
Glad to heat oyu are using us, thanks! You should get some lifters thrown in to save you money on shipping
Some people drill the guides, some people don't. Personally, I don't drill them but I don't have anything against it.
__________________
Old Apr 24, 2013 | 01:18 PM
Jadedbird's Avatar
Yeah. Im finishing up the fine details on my build, ill be shooting you a list thru your PM on here if you dont mind.
My grandfather used SDPC for his fairline and he had some quality parts from you guys
Old Apr 24, 2013 | 06:11 PM
litle88's Avatar
I have morels too the Cadillac lifters SUCK but if your looking for an Ls7 upgrade then the SLR lifters are for you
http://www.briantooleyracing.com/btr...r-lifters.html
Old Apr 24, 2013 | 10:01 PM
Jadedbird's Avatar
Havent heard much on slr. But ive heard alot of good from BTR
Old Apr 25, 2013 | 05:04 AM
texas94z's Avatar
Awesome company with awesome products. These lifters would be perfect for your setup.
Old Apr 25, 2013 | 06:56 AM
C5natie's Avatar
How common are lifters spinning in their bores? I know it happens but is it an issue? I think valve float is the main thing that kills lifters at high rpm. the plunger and roller get beat up and ends up eating a cam lobe. Since most common LSx vale springs used have wimpy pressures I guess it happens more then it should.
The people at Brian Tooley know their stuff and those lifters look solid. Might try those if i get heads later.
Old Apr 25, 2013 | 08:41 AM
WKMCD's Avatar
FWIW: I was one of the first to try the Caddy Racing lifters. I pulled them out after about 3k miles when a couple of them got noisy. They're really made for mild lobes and extremely light valve trains. I run PAC 1521 springs, 11/32 PR's and currently have YT's. The YT's are coming out this weekend - I've broken 2 from 2 different sets - and are being replaced with CHE rockers.
I run Morel Link bar lifters now with no issues.
Old Apr 25, 2013 | 08:47 AM
JakeFusion's Avatar
Super Hulk Smash
This. I run PAC 1904s in mine. CHE Rockers, Morels, and 11/32nds.
Old Apr 25, 2013 | 08:51 AM
MertezWS6's Avatar
I dont get people! why would you go cheap on one of the most important parts, do it once do it right. Spend the extra $130 and get the Morel 5290 link bar lifters and be done! I just got mine from Brian Tooley and the price is great. Anything aftermarket should not be using plastic trays and stock lifters.
Old Apr 25, 2013 | 03:53 PM
Alvin@PCMofNC's Avatar
LS1Tech Sponsor
I've never had a problem with the caddy lifters other than how noisy they are. Can't really go wrong with a set of LS7's. Especially for that application.
__________________
See what's in our shop on Facebook! Customer Build Blogs!
www.pcmofnc.com
Performance Installs - Dyno Tuning - Custom Camshafts & Valvetrain - Remote HPtuners Tuning - Mail Order Tuning & Sales
704-307-4227
Old Apr 25, 2013 | 04:23 PM
1989GTA's Avatar
I agree. I think for most applications the LS7 lifters are just fine. I have not really heard of any problems with them. If people want to spend the extra cash on the Morel lifters I have no problem with that. They also appear to have a good track record.
Old Apr 25, 2013 | 04:50 PM
USMC5811's Avatar
I put LS7 lifters in my 408 and havent had any issues. cant complain about the price either!
Old Apr 25, 2013 | 06:07 PM
Dyno Junkie's Avatar
What do ya think?
I'm using the factory LS3 lifters that came in the unopened engine with a Comp Cam. 231 239 .617 .624 113.
Old Apr 25, 2013 | 06:44 PM
Jadedbird's Avatar
^^^ thats impressive
